wheel/tire questions...
I am currently building my 73 2wd Blazer, and wasn't sure if the tire size I wanted would fit and also what backspacing on the wheels would be best. The truck is lowered 4/6.
I was planning on getting the american racing torque thrust 2 wheels, with 17x8's up front with 235/55 tires. I know that one will work, but wasn't sure on the backspacing. On the back I wanted 18x10 with 305/45 tires. I think that would fit with correct backspacing, but not positive. So what are your thoughts on that? Thanks, Brett |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: wheel/tire questions...
You need to run a 5" or 5.25" BS on the front and a 5" BS on the rear. As long as it has the stock rearend,... this should work.
alright thanks, and yea it will still be using the stock rear until something breaks haha.
