02-20-2006, 08:54 PM | #1 |
Location: Bondurant, IA but in Worcester, MA for school
Long Tube Headers???
I have a 1970 Chevy C20 and wanted to put a set of cheap ceramic coated headders on my truck and was wondering what part numbers would fit in there? I have a built 355 that is in there now and need a pritty decent size primary tube...im thinking 1.75" Anyone have any ideas. THanks
HotRod
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
02-20-2006, 08:56 PM | #2 |
Re: Long Tube Headers???
Don't use cheap and ceramic coated headers in the same sentence. They don't exist, unless maybe their used.. If your talking about the one in your sig, use either 1 1/2 or 1 5/8 headers.
Dynomax, Hookers, Doug Thorleys
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" Last edited by Bowtie67; 02-20-2006 at 08:58 PM. |
02-20-2006, 09:02 PM | #3 |
No its a different motor making about 525 horsepower. So I need a set with a good size primary. I just dont want to spend like $500 on a set of headers thats all. THanks
HotRod
02-27-2006, 01:22 AM | #4 |
anyone else???
02-27-2006, 02:15 AM | #5 |
Sinister Exaggerator
you can keep it down to around 300 if you keep it at 1 5/8. but as soon as you cross into the 1 3/4 headers they know you have hp and charge you a couple hundred more, I think it is a communist plot!!
02-27-2006, 08:00 AM | #6 |
67-72 Addict!
What are the specs on that motor??? Building 525hp out of a 350 could not have been cheap. I definitely wouldn't go cheap now. That must be a wild ride!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
02-27-2006, 08:25 AM | #7 |
Active Member
Try sanderson www.headers.com Real quality and a real decent price. Check out the cc3 small block headers you'll love them. I recently installed a set of coated QP2100 on my '72 454. They have 3/4" flanges and look soo old school...
My .02 -Fred |
02-27-2006, 11:12 PM | #8 |
The motor is a 355 SBC.
12:1 Compression Eagle 4340 Crank GM Pink Roads CC Solid Roller Cam Mighty Deamon 850 Carb Victor Jr. or RPM Intake...havnt decided yet Ported heads simmilar to Dart Pro1s and some other dodads HotRod
02-27-2006, 11:33 PM | #9 |
Watch out for your cornhole !
Summit brand coated headers are reboxed Dynomax brand. They have nice JetHot coating and run 190 a set. Only 1 5/8 though. I bought a set a few years ago and like them a lot.
02-28-2006, 02:59 PM | #10 |
Tx Firefighter - do you by chance remember the part number for those headers? Thanks
HotRod
02-28-2006, 06:15 PM | #11 | |
02-28-2006, 07:13 PM | #12 |
Captain Ed
I also wouldn't run the pink rods with that combo. They're just heat-treated stock rods and not sufficient for that much compression. Nor are they sufficient for the horsepower you are aiming for. You're putting in a $120 set of rods with a $300 camshaft?? Even a set of eagle I beam (SIR) rods would be a huge improvement over the pink rods. Have you dynoed this motor? Because 525 out of a 355 engine is mighty ambitious. Most of the 500+ hp 350's prove out to be merely 400+ hp (which is nothing to sneeze at). Not trying to insult here, just pointing out some realities.
If you ain't bleedin', you ain't workin'! 1999 C3500 LS 7.4L Last edited by ed455; 02-28-2006 at 07:21 PM. |
