Old 07-21-2002, 07:36 PM   #1
RON WOODGEARD
Resident Young Old Dude !
Question Brake Proportioning Valves
I'm done with the lowering and front disc conversion BUT.. I didn't consider the bias valve, After bleeding the system I don't have any rear brakes compared to the front, is that due to the proportioning valve ?
I have new rear shoes and adjusted them.
RON
RON WOODGEARD is offline   Reply With Quote
Old 07-21-2002, 08:41 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Did you replace the old drum junction valve with a disck/drum prop valve?
Actually, the rear drums would lock up first if you didn't...hmmmm
TTT then.
Old 07-21-2002, 09:39 PM   #3
nu2-72
A dick/drum valve and a brill? Where you been shopping?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 07-21-2002, 09:46 PM   #4
XXL
Seņor Member
XXL's Avatar
You may need a prop valve... but you also need to replace your front lines with smaller ones (1/4" I think... whatever is 1 smaller than what's on the rear). Without it, you get monster front brakes and nothing left in the rear-- good for standing your truck on it's front bumper but...
Kenneth
XXL is offline   Reply With Quote
Old 07-21-2002, 10:45 PM   #5
Longhorn Man
Ouch...that's twice with that typo...thanks, it was fixed.
Old 07-22-2002, 02:56 AM   #6
RON WOODGEARD
NO, I didn't change anything on the brake system except went to front disc. conversion kit. (you would have thought they would have everything that was needed in the swap kit) I'll call "TUCKERS IN VEGAS" tomorrow.
Thanks for everyones replies...........
RON
Old 07-22-2002, 07:20 AM   #7
Longhorn Man
You should swap out master cylinders and prop valves, and see what that does.
Old 07-22-2002, 02:34 PM   #8
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Don't screw with the brake lines, makes no difference, just the valve is all you should add, with a proper dual master cylinder.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 07-22-2002, 05:25 PM   #9
RON WOODGEARD
I touched bases with "TUCKERS" and they said the proportioning valve doesn't come with the conversion kit but it is needed.
an additional $89.95.
OH WELL, whatever it takes......
THANKS TO YOU ALL !!!!!!
RON
