Old 02-20-2006, 11:55 PM   #1
76bonanza
76bonanza's Avatar
foor shifter with bench
Looking to put in a floor ratched type shifter. I have a bench has anyone done this and not have to bend over really bad to shift? Tdp They make a long handle ratched type shifter?
Thanks pics would be good.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 02-21-2006, 12:04 AM   #2
71chevytruckguy
71chevytruckguy's Avatar
Re: foor shifter with bench
i think b&m makes a shifter for trucks. think its called a mega truck shifter or something along those lines.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 02-21-2006, 12:17 AM   #3
Jayss109
Active Member
Jayss109's Avatar
What 71chevytruckguy said. Truck light mega shifter. Ive got one. Mine works great. I do have long arms, but its not a that much of a strech. You could even space it up higher it need be. I can get some pics if needed.
J
________
Herbalaire review
Jayss109 is offline   Reply With Quote
Old 02-21-2006, 12:35 AM   #4
76bonanza
76bonanza's Avatar
Some pics would be nice.
1968 c10
lowered 3" 4"
Old 02-21-2006, 08:34 AM   #5
70c10
67-72 Addict!
70c10's Avatar
I have the regular car type Megashifter in my truck with a bench and I can reach it but the truck version would be better.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-21-2006, 12:14 PM   #6
76bonanza
76bonanza's Avatar
Anyone seen or used this one? looks like it would be longer.
http://go.mrgasket.com/pdf/automatic_shifters.pdf
1968 c10
lowered 3" 4"
Old 02-21-2006, 03:21 PM   #7
matthufham
don't worry about length, just get the light truck mega shifter from b&m and you'll be happy. i have a th350 version, make sure you get a th400 one so you have a 4 speed shifter window. actually you know what, i think they might come with both, you just install your window style for your application.
don't mind the button, that's my custom rocker switch for the backup lights since the previous owner yanked the reverse light switch on the shifter.
matthufham is offline   Reply With Quote
Old 02-21-2006, 03:42 PM   #8
dennislbrooks
dennislbrooks's Avatar
floor shifter with bench
me too
dennislbrooks is offline   Reply With Quote
Old 02-21-2006, 04:13 PM   #9
76bonanza
76bonanza's Avatar
dennis did you build that up?
Matt the th400 is also a three speed auto I am almost certin.
1968 c10
lowered 3" 4"
Old 02-21-2006, 04:15 PM   #10
76bonanza
76bonanza's Avatar
is it easy to hookup and do you just wire the rev switch from the shifter to the wire that goes into the column? Why did you leave your column indecator and shifter on?
1968 c10
lowered 3" 4"
Old 02-21-2006, 04:49 PM   #11
meathead95
computer illiterate
meathead95's Avatar
look at lokars website they have some nice long truck shifters but im not sure if they ratchet or not
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 02-21-2006, 05:53 PM   #12
raycn66
raycn66's Avatar
I have a 68 with a TH400. The previous owner moved the column shifter to the floor using a Hurst ratchet type shifter. It sat low requiring the driver to lean over to reach the shift knob--I disliked it so much that I bought a B&M Megashifter 'truck style' from Summit (PN BMM-80680). It's $174.95 + $8.95 for handling. As shown and mentioned earlier, it is a ratchet type shifter, easy to install, has a height adjustment, cable operated, and looks great and shifts great. I don't think you will be disappointed in your purchase, if you go this route.
ray
raycn66 is offline   Reply With Quote
Old 02-21-2006, 06:06 PM   #13
dennislbrooks
foor shifter with bench - Megashifter
No, I do not recall building it up on the mount --the outside housing does sit on the carpet.
Been a couple of years and I could not find a pic with housing off.
My 67 is a low hump truck.
Old 02-21-2006, 07:39 PM   #14
matthufham
th400's have 3 forward gears like the th350? interesting, i swore everybody was calling them 4 speeds because they had 4 foward gears. this link will answer many questions for ya, the installation instructions for the megashifter.
http://www.bmracing.com/media/products/pdf/10.pdf
Old 02-21-2006, 09:05 PM   #15
lngbed71
Nothing fits but the oil
lngbed71's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=163921
It's a Hurst and I built a pedastal for it (about 9") Haven't had nutttin but fun with it.
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 02-22-2006, 09:37 AM   #16
raycn66
raycn66's Avatar
Pics of my B&M truck Mega Shifter.
ray
Old 02-22-2006, 11:27 AM   #17
beater69
Sinister Exaggerator
beater69's Avatar
racyn66 what kind of bucket seats are those?
i guess thats a little off topic, sorry
beater69 is offline   Reply With Quote
