1972 c-10 1/2 ton upper ball joints help
I am replacing my upper ball joints in my 72 c-10 my question is on the new replacement ball joints do the thin metal bracket that holds the rubber grease cup go on top next to the ball joint assembly on top or below the the ball joint housing above the steering knuckle. Thanks in advance for any help.
Re: 1972 c-10 1/2 ton upper ball joints help
Also when heater is first turned on the heater blower fan squawls and screeches like its binding. Any ideas on this? Any body with any ideas on these two problems in this thread?
Thanks for any help |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Drop the ball joint in from the top and the grease boot goes underneath the arm. Put the bolts through the whole mess to sandwich it together.
Drill a tiny hole in the blower motor and lube it. Do a search under my name and blower motor. I posted on here just a few weeks ago where I did this same thing and how to do it. It was likely under a "what did you get donw this weekend" thread.
what he said is good // but you might also want to remove the blower an fan wheel assy from the housing and take a shop vac and clean out 35 years of accumulated crap to give yourself a better air flow thru the system
#5 | |
Rolled on Paint Club
![]() Join Date: Jan 2006
![]() Bob |
Just A Tool Hand
That is freakin halarious
:hit: |
Yeah, i had a 70 I changed out the heater core on, cleaned it up, it sill blew out leaves and dust out of the defrost for somtime later.
"Ochre Ogre"
As far as the blower motor goes, $18 or less and you have a new one and it blows twice as good as a the old one you have in your truck.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
To all of those that replyed to this thread many thanks. I have just finished installing the upper ball joints and getting ready to attack the blower. I am new to the site and will be posting pictures on my 3rd generation 1972 chevy c-10 1/2 ton truck soon to all to see. Thanks again for all the help and this killer site.
CG |
![]() Join Date: Sep 2005
http://67-72chevytrucks.com/vboard/s...d.php?t=187805 you mean this one tx?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
That's the thread. Thanks for digging it up.
I can't argue that a new motor may be better, but I am doing this truck as cheap as possible. Plus, I live an hour from a parts store, so that's like over 10 bucks of fuel just to go get one.
