02-21-2006, 02:12 AM | #1 |
C10 now is a GMC
Engine Mount Bolts
Hi Everyone,
Tonight I picked up the new rubber engine mounts, and tomorrow before I yank the engine & trans out of the truck, I need a few bolts. What size bolts do I need to mount the rubber mount to the side of the '72 350 sbc? Also the size on the 2 that holds the rubber mount to the tower? I never had side engine mounts on my '62, just a single front engine mount (wish bone type on '60-62's). TIA, David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project |
02-21-2006, 05:17 AM | #2 |
Re: Engine Mount Bolts
the side of the block will take 3/8" bolts. the ones that go into the mounts are 7/16" I think.
02-21-2006, 06:27 PM | #3 |
Watch out for your cornhole !
Agree, 3/8 bolt by 3/4 inch long.
02-22-2006, 12:33 AM | #4 |
C10 now is a GMC
Thanks Guys.
I picked up grade 8 bolts, washers, lock washers, & nuts this morning. Tomorrow, the fun begins. This morning before going to the hardware store, I put the side engine mount up to the side of the block. I'm running block hugger headers, and the passenger side just barely clears with approx a 1/4 of an inch. On the drivers side, it needs about a 1/4 of an inch taken off the top right corner in order to fit. Do you guys think it's wise to grind off a 1/4 of an inch off the 1 corner edge? TIA, David
02-22-2006, 01:46 AM | #5 |
grind away dude. making what you have fit is half the fun
02-23-2006, 02:38 PM | #6 |
C10 now is a GMC
Thanks Carl.
I had to angle the one edge not very much,then it cleared. Last night after I pulled the engine & trans out, and installing another TH350 behind the 350, my Dad & I lowered it back intot he truck to bolt it up with the '69 C10 engine mounts. EVerything bolted up right, except for the 1 bolt that holds the rubber mountto the engine towers. 1 engine mount was made in Korea, the other in India. They both came in the same box. After I ran the bolt(s) in, after getting snug, it would release,and would be loose again. I've found on a few spots on the trans that were metric bolts, could these 2 bolts be metric? What do you guys think? I'm getting ready to head back out there, and yank the rubber mounts off of the block to check the threads out. TIA, David
02-24-2006, 02:58 AM | #7 |
C10 now is a GMC
I fixed it. lol The made in Korea engine mount had to use a "machine" grade bolt, and the other just used a normal grade 8 bolt.
About an hour ago I finished her up, and took her around the blcok, boy there IS a big difference in 2 front engine mounts versus 1. That, and a good/nice & tight trans to boot. If anyone wants to see a pic from earlier today after I finally got the engine mounted in the frame rails, ill try to get it up asap. David
05-02-2006, 05:18 PM | #8 |
Chevyboy1962, do you have any pic's of your block hugger installation?
I am considering a set of block huggers myself, but would like to see how they look when mounted in a truck. Thanks /Tomme
1966 Impala 2D HT 1940 1/2 ton Truck |
05-02-2006, 06:30 PM | #9 |
I have purchased the India variety of engine mount before where the threads were metric (M10 if I remember correctly)
05-03-2006, 01:08 PM | #10 |
C10 now is a GMC
Tomme,
I have 1 pic on my webshots account that kind of shows how the block huggers are positioned. The pic is on webshots under "chevyboy1962" in the first album, last pic. I'd try to post a link to the pic, but I can't get it to link. David
