Old 07-21-2002, 08:14 PM   #1
nevada70chev
power brake question
i've got manual brakes on my 70 lwb, how hard is it to change out the master cylinder to one with a booster? i actually have the parts, but don't know the process etc. thanks for you help.
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat)
nevada70chev is offline   Reply With Quote
Old 07-22-2002, 10:10 PM   #2
Don Smith
If you are staying with drum brakes, you can just unbolt master cyl. from firewall and leave lines attached and move everything forward and install booster and bracket. You will also need the longer brake pedal rod. I did this before installing disc brakes, worked good.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
