Old 02-21-2006, 01:09 PM   #1
70rs/ss
70rs/ss's Avatar
urethane or rubber?
I am replacing the body mounts and immediately decided on urethane, that is untill I talked to Wes at Classic Chevy, he pointed out some things I had not thought about. He mentioned that the frames are made to flex and when wheeling they will flex a lot. Urethane does not flex, therefor the body will bare the brunt of the flex which will in time distort the body, break spot welds etc, etc. My question is, how many of you have swapped, what did you use and do you like them, and finally how is your Blazer used (wheeled, pavement, both) Thanks in advance for sharing your thoughts!!
70rs/ss is offline   Reply With Quote
Old 02-21-2006, 02:23 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: urethane or rubber?
I have not changed body mounts but I have read that the urethane mounts may squeek and cause a bit more of a rough ride. On the plus side, they should last much longer and you can get cool colors, like read.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-21-2006, 04:55 PM   #3
Putter
More Cowbell....
Putter's Avatar
.....plus......no one ever looks at their date and says....
"Hold on while I grab a urethane!"
Geeeeeze.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 02-21-2006, 05:55 PM   #4
vtblazer
vtblazer's Avatar
Geeeeeze.
vtblazer is offline   Reply With Quote
Old 02-21-2006, 06:02 PM   #5
70rs/ss
70rs/ss's Avatar
How about we keep to the subject? I am looking for information, not for my thread to taken in weird directions. If you used urethane great, tell me how they worked, if not how about you play somewhere else.
Old 02-21-2006, 06:40 PM   #6
bouncytruck
SKINNY TIRES RULE!
Wow. I was under the impression that this site was for fun. Sorry I replied to your post. I will make sure to keep all information 100% relevant to your specific situation from this point forward. I expect the same from you...
bouncytruck 1972 K5
Old 02-21-2006, 06:57 PM   #7
Burt4x4
Burt4x4's Avatar
I have had Energy Susp. urethane body mounts for over 10yrs now. I bought the black ones as I was told they are impregneted with polygraphite to prevent the "poly squeek" issue. The key to urethain is when you install the bushings do NOT over tighten the mounts. I used nylon lock nuts and tightend them carfully not to over crank on the nut. I have never found an issue with my body mounts. I even have a 3" body lift too boot.
My rig use to be a dayly driver but now it is towed to the trail.
So all in all I have had zero issue sence I installed the kit years ago...
If a urethain bushing is squeezed it cannot flex. So just make them tight but donot squeeze the mount and it will last a lifetime.
Burt
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 02-21-2006, 07:15 PM   #8
vtblazer
vtblazer's Avatar
I've used the red poly's.
Their on my "restored" blazer that never See's any off-roading.
I had also heard of the poly squeak so when I installed them , I smeared them all over with anti-seize and to date, not a sound.
Old 02-21-2006, 07:23 PM   #9
blazerboy72
I used urethane in my 72 and will only use rubber from now on. They squeak very bad ride rough and did not fit good. I will be ordering rubber for my 71 soon.
blazerboy72 is offline   Reply With Quote
Old 02-21-2006, 10:34 PM   #10
70rs/ss
70rs/ss's Avatar
Nah, not yours, but after yours it started to stray.... It is a site for fun as well as "INFO" which is why I posted this thread and just wanted this to stay on that path. BTW I usually keep my post to the point. Thanks!
Old 02-21-2006, 10:41 PM   #11
70rs/ss
70rs/ss's Avatar
Thanks for the info guys, I am going with Poly and I was figuring on the lube. I was not thinking they'd flex much, but the overtightening thing could be the reason for no flex. I found a set on a 4X4 site that are supposed to have bolts, so I'll get em and be the guinea pig. I'll keep you guys updated on the kit, it is like $75 and energy is $80, but the energy kit does not have bolts. Thanks for the thoughts!
Old 02-21-2006, 10:46 PM   #12
I would say the body stress is not an issue.Burt4x4 wheels his pretty good from what I`ve seen in his pictures.Can`t be as bad as body lifts,solid.I`m sure brand new OEM-type have got to be sweet.I`m thinking of going that route next.
Old 02-21-2006, 10:58 PM   #13
bouncytruck
SKINNY TIRES RULE!
Sorry, I was in a bad mood when I posted my last one. Sometimes ya gotta just kick back and have some fun. The serious info will make it. Actually, having more posts in a thread, serious or not, can generate more interest which will only get you better results in the end.
Besides, it was funny! "Hold on while I grab a urethane!"
Burt drive's his rig like it was intended. If he hasn't had a problem with flex, it probably isn't an issue.
bouncytruck 1972 K5
Old 02-21-2006, 11:12 PM   #14
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
I did poly on mine. Got the kit from Summit. Smeared them good with synthetic grease. For bolts I just got the proper length carrige bolts, nuts, and washers from Home Depot. If your rig hasn't had the mounts changed prepare to grind tack welds off. No strenous four wheeling for my blazer.
Never know, someday polyurethane condoms may be in.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 02-21-2006, 11:26 PM   #15
krue
Designated A-hole!
krue's Avatar
I don't see where someone cracking a joke is a hijacking a thread. It may be your thread but it's everyone's board. Take it easy and lighten up a little.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-26-2006, 09:27 PM   #16
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Heres a few pics of my blazer with poly bushings that I bought at summit racing..... I don't really wheel the blazer much maybe 4 times in the 5 years I have owned it??? No squeaks and lets face it its a blazer with a 6'' lift its gonna ride rough...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-26-2006, 10:15 PM   #17
72CSTC5
72CSTC5's Avatar
Amen Krue. Relax its Sunday. Last day of R&R before work all week. By the way, I bought the original rubber kit for my 2wd just because I have heard of body alignment problems with the urethane not being as forgiving. Putter, I thought it was funny!! LOL!!
72CSTC5 is offline   Reply With Quote
Old 03-01-2006, 12:08 PM   #18
Chevy Muscle
< 69 Blazer
Chevy Muscle's Avatar
Where did you find the kit with the bolts?
Chevy Muscle is offline   Reply With Quote
Old 03-01-2006, 02:11 PM   #19
70rs/ss
70rs/ss's Avatar
Well, funny you'd ask, because I just got the kit that was supposed to have bolts and it doesn't! I called the manufactuer before I ordered and they assured me it came with all the hardware including bolts. It came with the bushings, washers and the metal aligning bushing but no bolts. It was $78 through Summit Racing Part#11008. It seems to be the same as Energies kit, just few $$ cheaper. I wish I had ordered the enegy kit now that I know it doesn't come with the bolts. Oh well, it will work the same, urethane is urethane. As for relaxing cause its Sunday, go back and look when the post was made and the responses. Thanks, Krue I am aware that this is a Public forum, I was just trying to assure I got the info I needed, no harm no foul and as you can see I appologized above. I love the board and most of the members, and would marvel at a urethane condom, you could just turn them inside out and reuse.
Old 03-01-2006, 05:20 PM   #20
Yukon Jack
Post Whore
Yukon Jack's Avatar
I went with the rubber mounts for my K5 and part of the reason was to get all the bolts without having to source them on my own. Sadly my K5 hasn't moved since I bought it so I can't respond how I like them. I am using poly on my K20 with a body lift. I have never heard them squeak - course it is so loud, I can't hear much of anything other than the motor and the tires.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is online now   Reply With Quote
Old 03-02-2006, 12:20 AM   #21
qksilver
In swapping out bushings make sure you use good bolts. Home depot bolts..............NO. Between stress fractures etc........I was working, recovering a wreck out of the woods, yes frames are suposed to flex. The frame flexed enough to break my carrage bolts, the only thing holding the cab to the
frame on the drive home were the front fenders. I can only imagine what would happen in any kind crash impact.
qksilver is offline   Reply With Quote
Old 03-02-2006, 10:13 AM   #22
Chevy Muscle
< 69 Blazer
Originally Posted by qksilver
Home depot bolts..............NO. .
I second that!!
I believe that Home Depot only sells grade-3 bolts.
Old 03-02-2006, 11:12 AM   #23
blazerparts
Errrr, why not home depot bolts? In a connection such as a body mount with either rubber or polyurethane within the "grip" of the bolt, a hardened bolt is a waste of money. Add the factor that except for the radiator support and at the back by the tailgate, the head of the bolts are bearing on the sheet metal of the body which will fail long before a soft bolt.
While the frame may flex slightly, it won't flex enough to break a soft bolt at the body mount. If it flexed that much you'd be popping out windows, tweaking rocker boxes, etc. Frames are virtually rigid, the suspension is flexible.
Extreme conditions such as off road racing may require a harder bolt, but then the body would have to be modified with stiffeners at the bolted connection.
However if you feel better using a higher grade bolt, have at it. I'll be satisfied using my cheaper home depot bolts, which match the originals.
Oh, and chevy muscle, hope that "dumm" icon wasn't directed at me.
Old 03-05-2006, 02:37 AM   #24
13lazer
13lazers' blazers
13lazer's Avatar
i installed the red energy suspension kit with alot of grease, after some thought, i took them out. the blazer was 29 years old when i got it and most of the rubber was present. my biggest problem was the 3 broken bolts. i ordered the complete rubber kit from lmc. i had bad memories of my squeaky 71 camaro, my squeakier 67 el camino, and all the squeaky muscle cars in my high school parking lot. im just hoping to avoid all the noise. i just tightened all the o.e. mounts in my c5 and its very quiet. in my opinion, polyurethane is not a performance upgrade, and the polygraphite was not any quieter.
13lazer is offline   Reply With Quote
Old 03-05-2006, 11:16 AM   #25
Chevy Muscle
< 69 Blazer
Originally Posted by blazerparts
Errrr, why not home depot bolts? .
.....Durability of the part. You make an great point about it not being the weakest link in the mount, but I'm sure all of us have, or know someone who has had a broken body mount bolt.
Also, if these trucks are to last another 35 years, we will want to be able to remove the bolts again at some time. A harder bolt will be less likely to corrode over time.
Of course not, my 'dumm' icon was directed at Home Depot. They ONLY sell grade-3 and don't offer a better quality bolt. I think they should offer grade-5 and grade-8 bolts as well. I know grade-3 is ok for most general construction of homes, but a lot of HD customers are building other things at times (like projects on their vehicles)
