Old 07-21-2002, 09:31 PM   #1
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
backup/nuetral switch QUESTION
I messed with the little adjustment screws and housing for my auto steering column a few weeks back when I couldn't get the shift lever to move....did I put it out of it's adjustment? Will this have an affect on how the back up lamp switch works in combination with the shifting?? will I need to mess with the adjustment until I get the switch to work??????
P.s i asked for a price on a new switch and it was $11, is that right, i went to O'reilly's
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 07-22-2002, 03:11 AM   #2
Andy4639
Old member
Andy4639's Avatar
Cool N/B switch
If you tweaked the switch some yes you could have messed the switch up from coming on in reverse, I don't think it would effect the safety part, but not sure.
Best way to tell is have some one pull into reverse and see if the lights come on, if not move the switch til it does.
There nothing more worse than seeing a truck or car going down the road with it's backup lights on.
While you have it in reverse try cranking it and see if it starts, if it does then you no what you have to do.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
