Old 02-22-2006, 12:37 PM   #1
JAKES 68GMC
Aluminum slot wheels rule...
gear ratios
What is the highest gear ratio you can get in a 3/4 ton 4x4 with a Dana 44 front and a full floating rear axle. (Dana 60 maybe????)
JAKES 68GMC is offline   Reply With Quote
Old 02-22-2006, 02:15 PM   #2
Erl
Erl's Avatar
Re: gear ratios
I changed mine to 3:73 ratio with 33 inch tires. It was a Big improvement. I am putting a 700r4 in soon, so I will get overdrive. If you are sticking with the 4-speed then I would use a 3:53 ratio with 33 tires. You will need to buy new carriers.
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 02-22-2006, 07:09 PM   #3
JAKES 68GMC
Re: gear ratios
I was thinking around 3.55 would be good for the V6. Could I get the axles/pumpkins out of a 73-87 Chevy? Are all Dana 44s and 60s the same width??
Old 02-22-2006, 07:35 PM   #4
1969 GMC
1969 GMC's Avatar
Re: gear ratios
are you planning on replacing the axles? or just gears?
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-22-2006, 09:05 PM   #5
JAKES 68GMC
Re: gear ratios
Don't know yet. More research required.
Old 02-22-2006, 09:47 PM   #6
1969 GMC
1969 GMC's Avatar
Re: gear ratios
I believe 3.54 is the highest you can get for a standard D60. With the D44 front, you can get higher, in the 2.XX neighborhood.
Now would probably be a good time to get a newer front axle with discs, if you are wanting to do that type of mod. It would probably be cheaper to get a set of axles with the gearing you want, than to re-gear your existing axles. But that is just my 2 cents.
1969 GMC K2500
1996 Honda Accord
Old 02-22-2006, 11:40 PM   #7
qksilver
Re: gear ratios
I have a set with 4:10 and have seen them at 4:56, 4:88 and 5:13
qksilver is offline   Reply With Quote
Old 02-23-2006, 09:08 PM   #8
JAKES 68GMC
Re: gear ratios
Yeah, thats what I was planning to do. I'd probably keep my drum brakes because they are essentially brand new and the truck stops quite well(plus it would look more original.. I'll have to start looking around for some 3.54 axles. They are pretty common in D44 and D60's, aren't they? Thanks for the help.
Old 02-23-2006, 09:15 PM   #9
b454rat
Re: gear ratios
I don't think GM used 3.55s. I've seen alot of axles, but not those ones. Not saying they don't exist, just never seen them. I know they make 3.42s in the 44 and 14ff. I think I read somewhere that a Dana 60 front with either 3.23 or 3.42s. But you can get any gear ratios you want. Dodge and Jeep both used them, and they have 3.50s and 3.55s. Not sure how low (number wise) 44s go, I have a set of 3.08 D44/12b.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 02-23-2006, 09:26 PM   #10
JAKES 68GMC
Re: gear ratios
Aren't all those axles the same width, or are they different?? Jeep axles would be more narrow, for sure.
Old 02-24-2006, 09:59 AM   #11
shelby987
shelby987's Avatar
Re: gear ratios
are you just looking to get gas mileage out of the 305?
You will always have enough torque to move those tires....high gears or not......might I suggest looking into an aux. overdrive....or maybe a torque splitter from advanced adaptors....once you are done buying the axles, and possibly swapping in the gears, the cost might end up being just as much.
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 02-24-2006, 10:59 AM   #12
JAKES 68GMC
Re: gear ratios
Trying to get more mileage and the ability to keep up with normal cars on the road, without blowing a Grand-Canyon sized hole in the block. Just figured higher-geared axles would be the cheapest and easiest (finding a set that are matched)
I would think I'd have enough torque, I can idle it along in 3rd gear with no troubles.
Old 02-28-2006, 11:22 AM   #13
69gmcfleet
Re: gear ratios
My truck originally had the 4.56 gears in it and it had to be redlined to do 50mph. I no longer run the original V-6, now have 350. I changed my gears to 3.73 with new carriers. Now I am capable of 60mph at about 2500rpm. I went with the 3.73s because I plan on going to a 34 inch tire and I didn't want to ruin all my low end gearing and towing capability. I can still start the truck in 2nd with no load.
Jeff
'69 GMC K2500 LWB, '74 350/SM465/Rockwell T-221, cnD44/ffD60, 3.73 gears, 31" BFG's
(originally had 305ci V-6)
'05 VW golf
'84 HD Sportster XLX
'68 GMC K2500 parts beast
69gmcfleet is offline   Reply With Quote
Old 02-28-2006, 04:30 PM   #14
JAKES 68GMC
Re: gear ratios
Jeff, I can start in 3rd with the V6 and idle around.
Old 02-28-2006, 04:42 PM   #15
69gmcfleet
Re: gear ratios
I can relate to that Jake as my truck was the same way with the V-6, and the '68 I just got is the same. Actually 50mph was probably stretching the truth!
These trucks were made to work. GMC's rule!
Jeff
'05 VW golf
Old 02-28-2006, 04:54 PM   #16
JAKES 68GMC
Re: gear ratios
We've had it out on the road once or twice, and it would do 45mph no problems in 3rd,(and it wasn't turning that fast either, come to think of it) Maybe someone put higher gears in it back in the 70's to save fuel. I'll have to check that out, whenever I can get it in the shop.
Old 02-28-2006, 05:31 PM   #17
69gmcfleet
Re: gear ratios
My '68 has stock 4.56 gears. My small 31" tires on the '69 don't help either.
What are your plans for your truck?
Jeff
'05 VW golf
Old 02-28-2006, 05:40 PM   #18
JAKES 68GMC
Re: gear ratios
well i'm not sure yet. I was THINKING about lifting it 4", or 2" with add-a-leafs and run 33's (285/75). Going to get it repainted again, Hunter Green so it will match up.Needs a new transfer case, the Rockwell jumps in and out a lot. Power steering, I gotta have that. I've got plenty to do to it, but it is still in nice shape. I need to get rid of some stuff to get some money to buy a parts truck.
Old 03-01-2006, 06:17 PM   #19
69gmcfleet
Re: gear ratios
I hope to get a 4 inch lift on my truck and 34's this summer. I am in the process of rebuilding my t-case, my shifting fork loosened up and I lost Hi range. Power steering is a plus, my '69 has it stock. I prefer the older hardware found on these trucks, that is why I got a parts truck, since it is getting harder to find them. Mine was also repainted the stock color. I prefer a stock looking truck for the most part. Yours has lots of potential.
Jeff
'05 VW golf
Old 03-01-2006, 11:13 PM   #20
kwmech
Re: gear ratios
I have stock 3.54 gears in my 68 gmc 3/4 ton. ( 2 wd ) 3.54s would be the tallest matching ratio for the 60 and 44. If you look hard a 3.21 could be found for the front, but the match would be in a 14 bolt rear axle, kinda rare ratio for the 14 bolt but they can be found. 3.21 was a dodge 44 ratio in the mid 80s ramchargers
Old 04-15-2006, 10:12 AM   #21
JAKES 68GMC
Re: gear ratios
Another question....If I could get 3.54 gears from a Dana 60 out of a Ford truck, would the ring and pinion be the same for a newer axle versus a old one???
Would a 93 Ford F250 have a D60 rear????
Old 04-17-2006, 10:37 AM   #22
JAKES 68GMC
Re: gear ratios
Anyone know???
Old 04-17-2006, 01:20 PM   #23
Erl
Erl's Avatar
Re: gear ratios
Call Randy's Ring and Pinion.
Dallas TX
Old 04-17-2006, 01:30 PM   #24
Prerunner1982
Prerunner1982's Avatar
Re: gear ratios
dont have any input as far as gears are concerned...but my dad has a 65 k10 with 283 or 327.. sm420 and t221 and 3.73 with posi.. he uses it to haul 2.5tons of water regularly... even with a full load he still starts in 2nd gear.. i love that old truck..
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
