Old 02-22-2006, 05:12 PM   #1
53sparks
rubber cab and radiator mounts
Seems like this is a pretty popular topic, but i was wondering if any on has a detailed drawing or pic to show the order on the wasers rubberframe hangersand also what the radiator mounts look like i have some new ones but didnt come with any instructions or pics oh yeah for 67 2wd 1/2 ton. the main rubber bushing i have there is a metal bushing that sticks out about an 1/8 is that the top or bottom? any help would be appreciated Ron
53sparks is offline   Reply With Quote
Old 02-22-2006, 05:39 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: rubber cab and radiator mounts
There is a big hole in the frame mount. That 1/8 metal bushing surrounded by rubber sits on top of the mount and fits down into that hole. I got my kit from GMCPauls but I don't think it came with the big washer that sits on top of that (it goes between the mount and cab floor. I cleaned mine up and reused them. Under the frame mount you put the triangle rubber piece. Put the metal sleeve between the two. I coated mine inside and out with anti-seize in hopes they won't ever rust again. Put your bolts throught using a washer at the bottom of the triangle piece. The bigger bolt goes on the front, the smaller one to the back. I did this last weekend, check this thread out:
http://67-72chevytrucks.com/vboard/s...d.php?t=190013
I haven't done the rad. support yet, so I can't help you there.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-22-2006, 07:16 PM   #3
speedracer
Blank
speedracer's Avatar
I used the pictures out of an LMC catalog It worked out well
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi.
1977 Corvette 350-375hp 4speed, silver show car.
2002 S10 xtreme, work truck
2004.5 VW jetta GLI 1.8T 6speed, weekend warrior.
2013 Audi A3 TDI, the wife's car
speedracer is offline   Reply With Quote
Old 02-22-2006, 11:06 PM   #4
53sparks
here are the mounts i have i am guessing the two on the left are for the radiator support but the metal insert is to big to fit in the holes on the frame bracket thanks ron
