Old 02-22-2006, 07:02 PM   #1
kanuck
parts interchange 71 chev
I just went out and looked at a 71 or 72 C30 that I can drag home for $250, and yes it is a total rust bucket. What I was wondering is about the front disc brake spindles and control arms, are these all heavier on a c30 or is there anything that can be done with these to mount into a 6 lug half ton if I buy new rotors and ball joints? The brake booster and M cylinder is still in the truck along with the power steering box. The only body part that is any good is the hood, and parts of the grill are OK. Still has a flat deck and duals on and the 4 speed is still in place, none of which I need or want, just makes it heavier to move. Actually has nice vinyl factory bench with no tears, but what do ya do with it?
Hagen
'70 Malibu with 383 stroker/T350
'56 SWB Mercury pickup..under construction
'67 Firebird Convertible...all done stock
'70 LWB 350 on propane...beater
'69 LWB 350/T400 body restored
kanuck is offline   Reply With Quote
Old 02-22-2006, 08:32 PM   #2
dennislbrooks
dennislbrooks's Avatar
Re: parts interchange 71 chev
I believe the 1 ton spindles accept 8 lug Dayton type wheels and not sure if the a-arms are the same for 1/2 and 1 ton trucks --maybe. Sounds like a lot of work but you could use the 1 ton frame and put your cab on it. At least this will take thi sthread back to the top -- there are people out there that know.
dennislbrooks is offline   Reply With Quote
Old 02-22-2006, 09:07 PM   #3
junkyardjohn
junkyardjohn's Avatar
(quote)What I was wondering is about the front disc brake spindles and control arms, are these all heavier on a c30 or is there anything that can be done with these to mount into a 6 lug half ton if I buy new rotors and ball joints? (quote)
NOPE SORRY. THEY ARE NOT INTERCHANGABLE. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
