Old 02-23-2006, 08:11 AM   #1
70c10
67-72 Addict!
70c10's Avatar
Need some exhaust pics
The more I look at my exhaust, the more I don't like it. Does anybody have any pics of Full length headers (Not shorties or ramhorns) with a nice tucked up exhaust??. I want to shorten mine again to exit in front of the rear tires. Thanks
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-23-2006, 09:37 AM   #2
68jimmy
68jimmy's Avatar
Re: Need some exhaust pics
Try this. http://67-72chevytrucks.com/vboard/s...d.php?t=187968
It has quite a few good ideas...
good luck.
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 02-23-2006, 10:18 AM   #3
70c10
67-72 Addict!
70c10's Avatar
That's a beautiful job but he retained stock manifolds. I was hoping to see pics using full length headers like I have. Thanks
Jim
Old 02-23-2006, 01:56 PM   #4
speedracer
Blank
speedracer's Avatar
most full length headers hang down past the frame I had to use 3/4 length.
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi.
1977 Corvette 350-375hp 4speed, silver show car.
2002 S10 xtreme, work truck
2004.5 VW jetta GLI 1.8T 6speed, weekend warrior.
2013 Audi A3 TDI, the wife's car
speedracer is offline   Reply With Quote
Old 02-23-2006, 02:51 PM   #5
70rs/ss
70rs/ss's Avatar
The best you can do with full length is a little below the frame. I ran mine straight back to where the frame starts to turn up over the rear axle and jumped the pipes outside the frame there and up and over the axle and out the back. this works great for a lowered truck. I have no picts though. If I had it to do all over again I'd get the shorty Chevelle headers and run the rest of the exhaust the way I mentioned above and the pipes will be out of sight and and out on mind!
70rs/ss is offline   Reply With Quote
Old 02-23-2006, 03:35 PM   #6
Frizzle Fry
Frizzle Fry's Avatar
It's a Suburban, but it's what you're describing:
Frizzle Fry is offline   Reply With Quote
Old 02-23-2006, 04:47 PM   #7
70c10
67-72 Addict!
70c10's Avatar
Thanks Mike. Your mufflers look a little higher off the ground than mine so there is hope!
Jim
Old 02-25-2006, 11:48 AM   #8
70c10
67-72 Addict!
70c10's Avatar
Anybody else have some pics of exhaust with Full length headers?.
Jim
