Old 02-24-2006, 06:05 PM   #1
detroit72k5
detroit72k5's Avatar
Suspension Lift All Done, thanks for the Help!
I'm just about to order a 6" Skyjacker suspension lift and some 35s for my 72 Blazer. I was just wondering if there's any modifications necessary not covered by the kit, mainly the driveline. Any help would be appreciated.
Thanks!
detroit72k5 is offline   Reply With Quote
Old 02-24-2006, 06:47 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Suspension Lift Help
You may have to get the drive line lengthened, it just depends on the lift. Every 6" lift measures a different. You may need a raised steering arm if the lift doesn't come with one. Also, lifts 6" and up are prone to bump-steer. Cross-over steering usually solves the issue, but in involves fabrication and $. Check your rag joint and steering setup to make sure it is tight. The 35's will put a lot more stress on your steering and any problems will most likely get worse.
Post some before & after pics for us!
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-24-2006, 07:58 PM   #3
Medicanman71
Medicanman71's Avatar
My 4" bds lift is more like 6" My drive lines are long enough (looks like the front one might be maxed). at the same time I had a custom drag link/steering setup installed, it rides WAY nicer then before... the stiff susp. is WAY better then the beat as f!ck springs. But if you're an old guy the stiffness may not be to ur liking. I opted for 33's to keep ample tire stuffing room. Most ppl have 35's My lift dwarfs my 33's. Yea, cross-over steering - most of us will keep on wishing...
Medicanman71 is offline   Reply With Quote
Old 02-25-2006, 08:31 AM   #4
Blazerb61
with a 6 inch lift you will also need the front end and rear shims to angle your drive line the way it is supposed to be I made my drive shafts longer I run 35s and have 6 inches of susspension and 3 of body
Blazerb61 is offline   Reply With Quote
Old 02-25-2006, 01:07 PM   #5
bouncytruck
SKINNY TIRES RULE!
The angle compensations should be built into the lift kit. I've seen a few where the t-case has to be dropped, but I don't think that is on something as small as a 6" lift.
I've got a 6" lift on my '69 (rear blocks) and the angle is built into the blocks. There is a product call zero-rates that re-center the wheel in the wheel opening. They also have other purposes, but I'm not sure what. I think that Yukon has them on his flat-bed.
bouncytruck 1972 K5
Old 02-25-2006, 01:21 PM   #6
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Where'd you get your custom Drag link setup? You still wanting crossover steering? Is Custom Drag Link just temp?
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 02-25-2006, 03:24 PM   #7
Medicanman71
You cant have my drag link!!! Maybe i can find out what kind it is, i dont believe it was part of the kit.... an off road shop installed it and i think it was a type of piece they had a few of, as they did lift kits all the time. Also, said 4x4 shop is 300 miles north, so as much as i'd like to for you, i cant just pop in and pick one up...
I'll check and see if i see a name on it but i doubt it...
Old 02-25-2006, 03:30 PM   #8
detroit72k5
Thanks for the advice everyone. I guess I'll install it then see how the steering feels. It's already kind of loose now so I'm sure I'll have some work to do on it. I don't think I'll need the cross-over, but the drag-link's a good possibility, probably a steering stabilizer as well. I'll definitely post some pics when it's all done.
Old 02-25-2006, 03:37 PM   #9
Medicanman71
I always wanted a steering stabilizer for the cool effect
but really, your ball end joints are probably shot and its the reason why your steering is so loose. Mine were before i had my lift done, and with the lift and new ball end joints, like i said... rides like a ****ing cadillac
Old 02-25-2006, 05:43 PM   #10
bouncytruck
SKINNY TIRES RULE!
I've seen a drag link set-up like that on a later model Suburban before.
bouncytruck 1972 K5
Old 02-25-2006, 11:15 PM   #11
Scrubby
Check out GMTrucks.org
For my 4 inch tough country lift, I had to get both drivelines extended. I also had to get some shims to change the pinion angle back to kill the vibes. I still need to do something with the e-brake cables, but I'm not sure what I am going to do yet.
Scrubby is offline   Reply With Quote
Old 03-04-2006, 10:15 AM   #12
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
The only problem I raninto was my front drive line being too short but its outta someother 4wd and not a stock piece.. I used a raised steering arm to correct the steering isses but it still has massive bump steer. I do have the box and steering shaft for the crossover just need to get time and a little $$$$
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-11-2006, 02:02 PM   #13
detroit72k5
Quick question, I'm working on the lift today and Skyjacker provides a small L-shape bracket for relocating the brake-line, but no installation instructions or pictures. Anyone have a picture or explanation of how this should be done? THANKS!!
Old 03-11-2006, 10:08 PM   #14
orange72blazer
orange72blazer's Avatar
I sent you a PM. AS far as the drive shafts go I had to legnthen the rear 2" after I installed my 4" lift.
1972 Chevy Blazer
1997 GMC Sierra
2009 Chevy Tahoe
orange72blazer is offline   Reply With Quote
Old 03-12-2006, 10:18 AM   #15
FRENCHBLUE72
PROJECT 7DEUCE
The L-bracket should be for the rear line set bolts to the diff cover IIRC
MEMBER #6377
Project "7DEUCE"
Old 03-12-2006, 10:42 AM   #16
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Mine is straight, but my arm is angled alot more than this
(The piece on the left side of the pic, whatever it's called)
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-13-2006, 10:18 AM   #17
detroit72k5
Again, thanks for the help everyone. Progress pic. Front's all done except steering stuff, back is half-way done, hopefully I can finish it up tonight if there's no more bolts that have be cut through, but I'm sure there will be...
Old 03-13-2006, 04:55 PM   #18
cleszkie
cleszkie's Avatar
That drop drag link is made by Superlift. I've got one on my K5. Recommended for 4" to 6" lifts with stock steering arm. I don't have the part number handy, but it cost about $130.
cleszkie is offline   Reply With Quote
Old 05-08-2006, 09:31 AM   #19
detroit72k5
Just wanted to say thanks to everyone for the help on the lift, brakes, and steering. Finally rolled the truck out of the garage yesterday and was happy that the roll bar fit under the garage door. I think I'll have to just go with 33s instead of 35s, but we'll see.
Thanks again!!!
Old 05-08-2006, 07:10 PM   #20
Medicanman71
Hey Hey, looking good! so you went with skyjacker? Nothings wrong with 33's, more room to stuff them After all, i have 33's and 6" of lift. I'd be interested in more pics of your steering stablizer and what brand, $ etc.
Old 05-08-2006, 09:10 PM   #21
detroit72k5
Thanks! Yep, I saw mixed reviews of Tuff Country and Rough Country lifts, but all the Skyjacker reviews seemed good. I found a good deal on the Skyjacker lift at autoanything.com, they had a 10% off coupon and free shipping so I think it was $900. I got the new steering arm, drag link, and steering stabilizer from ntwonline.com , it's a Skyjacker steering stabilizer, $90 for the kit. I want to put the stickers on the shocks, but they're lost somewhere in my mess of a garage which will soon be cleaned up Medicman, I'll get some more pictures of the stabilizer tomorrow. Can you post a side pic of your truck with the 33s?
Old 05-09-2006, 06:17 AM   #22
vtblazer
vtblazer's Avatar
detroit, lookin' good.
JMO - 33's look best with a 4" lift and 35's go better with a 6"
There's always gear ratio's to consider (and garage door height) but 35's would give you that little extra ground clearance when wheeling.
vtblazer is offline   Reply With Quote
Old 05-09-2006, 02:25 PM   #23
Medicanman71
On the other hand, as in my case, 35's werent exactly in the budget
Also my BDS 4" lift turned out to be more like 6" if not exactly a 6" kit.
I'm pretty happy with it, have thought about putting some zero rates in the FRONT, but i'm not sure...
anyways, here it is, 33" with 6" lift. Makes the 33"s look small. Left the gears in it that have been since i got it, dunno what they are, but she's no dog!
Old 05-10-2006, 03:15 PM   #24
detroit72k5
Thanks for the pic Medicman, here are some pics of the stabilizer, let me know if you need more info. I think 35s look better with a 6" lift as well, the only factor is the garage door, but I measured last night and have 4" of clearance at the roll bar with the 31s (that actually measure 30"), so with the 35s, I should still have a little over 1" of clearance. Off to the tire and alignment shop this weekend!
P.S. We need a 1st Gen Blazer Smiley!
Old 05-10-2006, 03:35 PM   #25
Pop's72
It's ok to stare...
Pop's72's Avatar
Looking good... Can't wait to see the finiished product.
Pop's72 is offline   Reply With Quote
