Disc Brakes
I am looking to upgrade my rear drum brakes on my truck to discs. Does anyone know any OEM upgrades so I don't have to break the bank doing it....I would like to keep the parking brake but it is not that big of deal depending on what needs to be done.....thanks for any help you can offer
JIM 1976 6 lug rearend chevrolet truck |
Re: Disc Brakes
1987 350 TBI lowered 5/7 |
Re: Disc Brakes
Didn't IROC's have discs on back? If so, why couldn't you swap one under a truck? just curious.
Re: Disc Brakes
Thanks guys for the help so far.....I am looking for a cheap and reliable upgrade, I will check into the Camaro upgrade...keep the comments coming
Re: Disc Brakes
Not sure about a 6lug set up... any I have heard about are from 5 lug cars.
Ben 1983 Silverado SWB 305 2002 Silverado Extended Cab 5.3 http://members.shaw.ca/bkennett |
You get what you pay for
![]() Join Date: Dec 1999
Re: Disc Brakes
Well, you have cheap and you have reliable, but the two don't go together. A good, reliable, rear disc setup will not be cheap. I've got a good setup but it's very far from being cheap.
Just my nickels worth.
Mike 1985 Chevy C-10 |
![]() Join Date: Sep 2005
Re: Disc Brakes
There is a 6 lug set-up for sale on Ebay.
#8 | |
Re: Disc Brakes
bigarmzz, do you have this kit on your truck?
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
Re: Disc Brakes
I bought this set and I am going to install this week.
#10 | |
Re: Disc Brakes
Re: Disc Brakes
Just as well start thinking about buying a disc/disc master and combination valve. Oh, and if you got the e-brake calipers, you are going to need to buy some new cables to make these work right.
Good luck and let us know how it works and the quality of the parts. Mike |
#12 | |
Re: Disc Brakes
#13 |
BAD BOW-Silverado XST
Re: Disc Brakes
I found this kit http://www.ecihotrodbrakes.com/rear_...nversions.html
Don't forget a Caddy or Lincoln rear ends. Both 5X5 bolt patterns. |
#14 |
Re: Disc Brakes
#15 |
No Life Like Low Life
Re: Disc Brakes
Here is a pic of what I'm running out rear on my 12 bolt
Eric 1978 Chevy Scottsdale 1960 Impala ZZ4 1965 Buick Riviera GS 2011 GMC Sierra Denali |
#16 |
*Proud Member*
Re: Disc Brakes
I have rear discs from a 93-97 Camaro in my ride... it all was 100% bolt up, but my rear axle is from a 69 Chevelle.
You do have to think about getting a new proportioning valve as stated above... go here to get one: http://www.inlinetube.com/Prop%20Valves/PR-101.htm ![]() ![]() |
#17 |
Re: Disc Brakes
Try a 79 Cadillac seville. I was told that the rear disk brakes can easily be
adapted to any 10-12 bolt rear ends? |
#18 |
Re: Disc Brakes
So....what if you have a 3/4 ton?
Anyone done that conversion? |
#19 | |
yeller
Re: Disc Brakes
http://fourwheeler.com/techarticles/...129_0504_disc/ I have this linked to the garage section on 73-87.com
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#20 | |
Junior Member
Re: Disc Brakes
1971K20 Eaton H072 Rear
69'GMC 3/4ton 350 4sp 71'GMC 3/4ton 350 4sp 71'K-20 383 TH-350 Orcas Island, Washington |
#21 |
Re: Disc Brakes
i have put a f*rd nine inch w/ disc from a lincoln and the back brakes dont work i need the proportioning valve replaced for disc but the one above is a 50-50 split i dont think i like that shouldnt it be more like 70-30? to be safe! let me know 75stepper if your brake took some getting used to or was there any diffrents other than being better due to disc in generall
square body trucks an addiction or an investment either way they consume all my extra time and money |
#22 | |
Re: Disc Brakes
Sorry I didn't see this earlier to thank the guys for supporting Blackbird's. Just for a quickie. If you look at my sig you will see my stocker '72 3/4ton with a dana60 rear with disc brakes. all stock brake system. I tow and haul quite a bit and never had issues.It is my daily driver. I have installed kits on the eaton and 14b ff (similar kit), both customers have not changed any braking system items. It really becomes the customers choice and what he wants to feel when he hits the pedal. i know what you'll say.. I work for blackbirds, so I'm biased... I'm not.. There are several places to buy kits. TSM is a good place, he will also state that you don't need to change your proportioning valve or MC. we have been doing kits for almost 6 years of online sales and have become the largest online supplier of complete kits with the most kits available. Before that we just handled word of mouth and local kits and other fabricated items. You don't become big time by selling items with issues or problems.. yes they do come up. Not everything we make can be perfect, but when that happens we work one on one with the customer to get them handled and back on the road... Again we are just an option. There are several guys out there with cheaper items, non tetsted blue prints and used parts to get you a rear disc system. There are also fellow board members that have done kits for them selfs. Just becareful and do your research. Heck we even have a review of our 60 kit on the pirates4x4 site. Any questions guys and i'll be glad to answer. Plus remember... Our prices are to your door...The other places mentioned add shipping and handling to the prices that are shown..
Support The Board Last edited by drink2mny; 04-04-2006 at 09:42 PM. |
#23 |
Re: Disc Brakes
14 bolt disc brake conversion http://www.shakerbuilt.com/14_Bolt.html
#24 |
![]() Join Date: Feb 2003
Re: Disc Brakes
I am also interested in converting, and I also have a 3/4 ton eaton. I have read that calipers for a 77 & 78 Eldorado will work for the conversion. I saw a complete set of rear calipers for a 79-85 Seville, will these work also? It says they are for a 1" wide disc. I guess you just buy the 8 lug compatible rotor?
Thanks for the info guys. Scott |
#25 |
Junior Member
Re: Disc Brakes
I am a new comer to this subject but it sounds to me like a kit is the way to go, all the parts come together and its been tried before. A guy could do a lot of running around picking up parts and then not have a compatable system. I am giving the Blackbirds kit a try and it will be two weeks before I am running it but i will post my results. If you have not already; check out Blackbirds Custom Trucks, they have a system that does not require any mods to your master cylinder.
