radiator support bushings for 67 or 68
Does anyone have a picture of a radiator support bushing for a 67 or 68. I am trying to put a 67 support on a 71 frame and want to make sure i purchased the correct bushings.
![]() ![]() Join Date: Jul 2002
Re: radiator support bushings for 67 or 68
The support cushions/mounts are the same for 67-72, These are on GMC Pauls site.
![]() In case you didn't know, you cannot use the 67/68 radiator core support with 69-72 fenders/hood.
They 67-68's are thinner than 69-72 BUT they dont fit in the frame holes for a 69-72 the 67-68 have smaller holes in the frame
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Hmmm didn't know that.. Seems they market them all the same.
So if im using a 71 frame do i need cushions for a 71 or will they make the 67 front clip sit too high ?
Vortec in the works
Use the bushings for the front clip your using.The bushings will fit your frame,67-68 are diff from 69-72
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
Wont the frame holes on the 71 be too large for the 67 bushings ?
Yes. You will need to weld the holes up to be smaller in order to use the 67-68 mounts.
Okay - let's settle this one for once and for all.
I know the diameter of the 67/68 bracket is smaller than the 69/72 bracket. I have not seen any difference in the mounting area of the different year core supports - i.e. built up or stepped down or anything. I also have not noticed any difference in the placement of the brackets between 67/68 and 69/70. That's not to say there isn't any difference but I just have not seen any. I believe you should use the correct bushing for whatever frame bracket you have. If anyone knows of a difference please post it here. This has come up before and I would just to resolve it so we don't have to guess anymore. Thanks for your comments and thoughts on this - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Vortec in the works
the only difference is the thickness of the bushing. the mounting tab on the frame should be the same(at least it is on my 68 frame). The 67-68 mounts just rest on top of tab, thet don't mount like the cab bushings.
I got into this when I decided to put a 68 clip on my 71 C10.
When I start to trail fit-up the clip I kept having problems, that's when I noticed that some vendors make different core support bushings for 67-68 that those for 69-72. I know the LMC catalog shows the same bushings for 67-72. I also have seen the difference between the frame horns for the 67-68 and 69-72, the 69-72 having the larger diameter holes. Do the holes in my 71 need to be welded-up to make a smaller diameter hole, so that I can use the 67-68 core supp bushings which are a thinner thickness if I remember correctly. Regards
Richard Dobson |
#12 | |
The fenders will not line up correctly with the thivk 69-72 core support mounts.
