15 in rally with 5,7 drop
hey,i got alot of good advice a few months back on what tire size to run on 17 in tt,s,on a79 fleetside swb.however,due to financial reasons,the 5 and 7 drop's going to happen but i'm going to run the stock 15 rally's for awhile.what sizes fill the well decently,i've got a couple of 265/50/15's for the front and was thinking 295/50/15 in the rear.or would these look too short?
Insert Witty Text Here
Re: 15 in rally with 5,7 drop
I would not go over a 275, assuming you have 8 inch wheels.
If you go with 3 inch spindles, you may have problems with the LCA or the caliper hitting the wheel with the 15s. Slonaker |
The Peacemaker
I agree with Slonaker that a 275/60 is big enough on a 8" wheel, no more....if your going to run 8" and 10" wide rallys with 265/50's and 295/50's then the set up would pretty much be similar to mine...the only thing different would be the offset of our wheels...tire sizes would be the same. Lol, my TT2's actually have the offset for a SWB, they barely fit on my stepper, I should of moved the rear wheels .5" in. But if your going to run 8" rally's then go with a 275/60 rear and a 255/60 front thats a pretty good combo, or you can try Longview tire, STS, Scwabs and see if any of them can find you a 10" wide rally.
1978 Chevy 2wd Stepside aka "Audrey" Cordova brown with mandarin guts 79k original miles & being restored 1979 Chevy 2wd Short Wide aka "Emma-Jayne" Cordova brown with mandarin guts 2019 Chevy Tahoe LT Previous rides: -2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB. |
MY EX DRIVES A BROOM
i agree with babyblue...that's the combo i'm running on my blaze
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
| Bookmarks |
