Old 02-25-2006, 10:55 PM   #1
harlyworkr
harlyworkr's Avatar
Commonality between 72 and 73 trucks
Are there a lot of parts that are interchangable between generations? Does the gas, brake, clutch mech interchange?
harlyworkr is offline   Reply With Quote
Old 03-01-2006, 09:40 AM   #2
Re: Commonality between 72 and 73 trucks
Not a whole lot of interchangeability or commonality between them.Basically,Anything that is connected to (on,from) the body will be different.I have used 73-up auto trans linkage on a`71.
Old 03-01-2006, 11:02 AM   #3
matthufham
brake boosters fit. front sway bars fit. engine mounts can fit. shocks... i'm out of ideas.
matthufham is offline   Reply With Quote
Old 03-01-2006, 11:29 AM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
I think you can swap an entire front suspension (cross-member and all) and from 73 to a certain year (79 or 80??) you can swap power steering boxes with either a shim or use your current 67-72 pitman arm (that's if you don't swap the entire suspension). Being that the cabs are different I doubt the pedals would be a direct swap, but who knows, maybe the do? You can swap engines and trannys with a mod or two as well You can also use the seatbelts and seats, but they are not a "direct swap."
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-01-2006, 07:26 PM   #5
72 CustomCamper
huh ???
72 CustomCamper's Avatar
The gas petal assembly will swap over. I have an 86 petal in my 72...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
