Old 02-26-2006, 12:51 AM   #1
Trifelynn
Trifelynn's Avatar
help with differences in 67-72 pickups
I am having a discussion with a friend, and he does not believe me about the differences. I looked through FAQ, and did not find a post on what the differences were, so I figured I would come to the experts
and hope you guys had a link to the differences.
Thanks guys/gals
Always looking for a 2wd blazer
Trifelynn is offline   Reply With Quote
Old 02-26-2006, 01:09 AM   #2
70blazerpickup
Re: help with differences in 67-72 pickups
67s have a different kicks and bends in the frame especialy the fround frame horns. the 68,69, 70 i bileive are the same exept for the nose. 71, 72 the trucks got the open nucle front end that is almost identical to the 73 and up exept that it is narrower. hope this helps.
70 blazer/pickup 104" wheelbace
70blazerpickup is offline   Reply With Quote
Old 02-26-2006, 02:48 AM   #3
pjmoreland
pjmoreland's Avatar
Here are the most obvious visual differences:
67-no sidemarkers, 45-degree slant to front of hood, plain double-slit steel grille, small rear window (large Panoramic window was an option), lower bodyline trim that follows the wheel arches, 6-lug wheels.
68-sidemarkers added, no more small rear window, otherwise looks pretty much the same as the 67
69-Front of hood made steeper, aluminum double-slit grille with black plastic "egg crate" inserts, bowtie emblem on front of hood, lower bodyline trim made wider and no longer follows wheel arch, upper body trim added
70-Black plastic grille inserts have louvres on them, rear axle widened mid-year
71-Aluminum grille frame no longer has center bar, and egg-crate insert is much more pronounced, bowtie mounted in center of grille, front turn signals mounted in front bumper, 5-lug wheels, front disc brakes
72-Rear-view mirror glued to the windshield, plastic inner door panels, extra screw on inside of door just under vent window
pjmoreland is offline   Reply With Quote
Old 02-26-2006, 03:10 AM   #4
pjmoreland
pjmoreland's Avatar
1967
Old 02-26-2006, 03:11 AM   #5
pjmoreland
pjmoreland's Avatar
1968
Old 02-26-2006, 03:13 AM   #6
pjmoreland
pjmoreland's Avatar
1969
Old 02-26-2006, 03:14 AM   #7
pjmoreland
pjmoreland's Avatar
1970
Old 02-26-2006, 03:15 AM   #8
pjmoreland
pjmoreland's Avatar
1971
Old 02-26-2006, 03:15 AM   #9
pjmoreland
pjmoreland's Avatar
1972
Old 02-26-2006, 09:07 AM   #10
Could you be more specific what differences you`re debating?Basically,every two years the front-end styling changed,but that`s obvious.
Old 02-26-2006, 11:27 AM   #11
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
you didn't mention if you was talking about chevy's or GMC's, GMC was a different animal and the grilles also changed throught the years, help us out.
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 02-26-2006, 11:28 AM   #12
Hook'em
Hook'em's Avatar
Try this link: http://www.rayschevy.com/images/guides/ident/year.htm
Hook'em
Hook'em is offline   Reply With Quote
Old 02-26-2006, 11:39 AM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The longhorn info on rays chevy is inacurate. (His info was pirated, Just like most of the descriptions ont he web for these. Go looking around the web, and you'll find the exact same info, word for word everywhere else on the web)
That orange truck up there posing as a 69 has a 70 grill on it.
Old 02-26-2006, 11:46 AM   #14
The 67-72 Chevys are all identical.Just look at the headlight,see?
Old 02-26-2006, 12:07 PM   #15
mudpuppie
mudpuppie's Avatar
queston , being new at this and working off and on on mine , if there the same why is the radiator support on 67 and 68 same and 69 to 72 the same ......????
mudpuppie is offline   Reply With Quote
Old 02-26-2006, 12:20 PM   #16
1LoC10
Insert Title Here
1LoC10's Avatar
He was being sarcastic.... the supports are differet because the grills and the angle of the hoods are different
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 02-26-2006, 12:33 PM   #17
Hook'em
Hook'em's Avatar
I found the site useful regardless of whether or not the information is orignial or not. I am certainly not attesting to the accuracy of everything on his site and if I wanted information specific to longhorns I would definately check your site first.
Hook'em
Old 02-26-2006, 01:06 PM   #18
Longhorn Man
Understood... just don't want some one new to the game seeing bad info and making it the rule in there head. Like many people do after looking at the LMC catalog.
Old 02-26-2006, 05:55 PM   #19
pjmoreland
pjmoreland's Avatar
1969
Old 02-26-2006, 05:55 PM   #20
pjmoreland
pjmoreland's Avatar
1970
Old 02-27-2006, 01:39 AM   #21
Trifelynn
Trifelynn's Avatar
Im sorry I was not spefic in what I was looking for. PJ got me more than covered and I appreciate that. This board is always the right place to turn to.
Lenny
Old 02-27-2006, 10:08 AM   #22
So,your friend didn`t notice the grilles were different?
