![]() Join Date: Jul 2002
I need a hug.....lol
Okay.....I'm knee deep into a yard improvement project....loading and hauling dirt away with my 72 Blazer to my property......then it happens.....that sickly sweet taste on your lips.....yeah, you know the one.......antifreeze. So as I'm looking at the green river dump into my passenger floor.....I'm thinking...wow....thats gonna suck to replace.
So.....I get it all apart.....except for that one nut.....yep...the one on the bottom.....un-reachable for clowns like me that cant keep their tools organized....or locked up in the pump house at the other property....doh!!!! I tried everything......and I need to get the vehicle going tomm.......this is where it gets ugly.....I did have access to my grinder.......muh-huh-huh!!!!!! Yes, I cut a hole in my wheel well.....to gain access to that last dang nut.......now keep in mind my passenger wheel well is toast up front...so I knew this wouldnt be fatal...and I have a welder...so I can close it up. So....I have to ask........am I the only knucklehead that has done this? I feel silly for doing it......but it worked like a champ!!! So....In leu of a hug....I have a Corona.......have a good night people!!!! ![]()
Patch |
Saving 1 truck at a time!
Re: I need a hug.....lol
You know...I never thought about putting an access panel in there. I have toasted inner fenders too and several old inner fenders to act as patch panels. I am going to put an access panel in mine!!!!! Did I mention that I have my new heater core mounted to the inner fender temporarily...fat lot of good it does there....LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
I was thinking about an access panel too......not that it would get used that much.....but with the Air Con.....that box is just too big to get under it....well...it was tonight anyway!! lol
Now.....I have to ask......hows that heater working out fer ya? : )
Patch |
The only way to reach that nasty nut is to drop the inner fender anyway, so you did the next best thing.
If that inner is toast already, it's fair game for 'get-r-done' |
its all about the +6 inches
You can cut a small hole, and use a plug to cover it in the 10 year streaches where the core isn't being used.
I was just fixing to post a "How Do You Get to the Dang Nut' thread...and here it is. Doing mine today. Just broke the old box off (it was busted up) and trying to put it back right.
Good Idea Longhorn Man.
67 C10 Shortbed 327 05 F150 4x4 NO APPOLOGIES ![]() 02 Xpress X19 02 Yamaha VMax 150 www.xpressboats.com Nothing says 'poor craftmanship' like wrinkles in your duct tape |
Designated A-hole!
That's a dang good idea!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
I suspect the General would be proud. '70 Pontiac Catalinas had an embossed ring on the right front wheel well. The ring was to be cut out if it was necessary to replace the blower motor, then welded or screwed back in, using seam sealer as necessary. Worked like a charm on mine.
Jamie Hyneman is my twin
![]() Join Date: Nov 2005
I had a similar problem on a different vehicle. I cut a hole with a hole saw and put in a rubber plug that I got from napa. I just went in and ask for a grommet that would plug a hole. I brought the hole saw with me. I liked the rubber because I knew that If I needed back in there it would be very little work.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
I am a Referee of life.
My 67 got modified.I slotted out that bolt ring and threadlocked the screw so that just enough of it was out that the cover could slip over that screw.You can't even tell it was done unless you take it apart.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Out of the carpool lane.
Patch, did you ever get that wheel problem fixed?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
Which wheel and how long ago? My memory sucks lately.....lol
Patch |
#13 |
Weren't you having some front end vibration problems that I talked to you about?
#14 |
Oh yeah....still am. The right front tire is tipped out from the top.....the opposite of what it would look like with a worn ball joint or a bent hub.....it's weird.....but I am almost ready to swap to my 3/4 ton set-up as soon as my rear disc brake kit shows up.
I've swapped in new ball joints for giggles and it's still the same. As soon as my wife gets back in town with our digital camera...i'll send you a pic of it. ![]()
Patch |
