![]() Join Date: Apr 2004
Vintage Air install
Anyone have Vintage Air installed on their Blazer? How hard was the install? How much did it cost you?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
fabricator of anythng not wood
Re: Vintage Air install
i just installed a v air compact heat/ac and it was a breeze
did you have a AC dash? how much was the kit?
ttt
WTB this ad
I don't have a Blazer but I do have Vintage air on both of my trucks. If you have basic hand tools and the ability to read and follow instructions you are in! The kit comes with everything but pulleys and a belt. The instructions are well illustrated and written. I want to say the price of a sure fit system is about $1100. They make a kit for factory air cabs, non air cabs, using non air heater controls, and using factory air controls. You can use factory vents or the ones that come with the kit.
did you use a non air dash? do you change the backplate for the controls?
#7 | |
The LuvShack Garage
I have seen both of Asa's trucks, very clean install ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
It sounds like your Blazer is non-air. I installed the VA system in my Blazer. Mine was a non-air dash. You have tons of options for the install... stock vents, VA vents, stock heater control, stock AC control, VA controls, etc. When you order the kit you can specify what components you want to use.
I chose to go with stock vents and swapped out my heater controls for stock AC controls. I cut the holes for the vents basically by eye using the stock vent as a template. The side vent holes look pear shaped, but actually it is the curve of the dash that gives them that look. When viewed from the front they are a circular hole. Mounting the evaporator is a piece of cake. I can't tell you what is involved in mounting the compressor because I cheated big time and installed a VA frontrunner serpentine setup. The VA setup works great (hot and cold!). Couple of pics:
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod Last edited by 71RestoRod; 03-01-2006 at 11:52 PM. |
I don't have a blazer now, but if things work out, I should have one in less than two weeks. It doesn't have air, hence the questions. thanks
