Old 02-26-2006, 02:55 PM   #1
Misled
Misled's Avatar
The 9,999,999th Eaton ID Question...
.....OK, before ya bust my butt or not searching....I did, and I'm either too dumb to find the answer or this really is confusing....
Identifying numbers found...
Casting number "3934635" on the 3rd member
"T PW 052 702" stamped on the 3rd member
I was under the "assumption" that the HO72 had the load bolt. My red circled area is the load bolt, correct? This is a from my son's 1970 K20 and there were only a couple owners before us, so I think it is all original, which most sources say this should be the HO52. The stamped number includes a "52"......I suppose that would be too simplistic, huh?!?!?
I will also assume that I have the open differential, since each side will spin opposite of each other in my fingers. (I know, I'm REAL high tech!!!)
Can ya guys (gals) help me?!?!?!?!
Thanks,
Misled
Misled is offline   Reply With Quote
Old 02-26-2006, 04:41 PM   #2
Rod
Re: The 9,999,999th Eaton ID Question...
The same guts would bolt into either diff the H052 or H072...so not sure what you want to know..but either will work..and yah that one has the load bolt. It's not the guts that matter really..you just take that whole third member and swap it in....that's the easy way. They both use the same axle spline count. The load bolts on both the H052 or H072...but on the latter years.
And from what I can see from your pic its not as detroit locker...I got em ..and there is no locker as I can see the inner gear in the pic.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 02-26-2006, 06:33 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have owned 2 HO52's, and they both had that deflection bolt, just like my HO72.
Old 02-26-2006, 07:09 PM   #4
Misled
Misled's Avatar
Thanks guys, for your help........
I guess the big reason I'm asking is for proper documentation of the truck, buying parts, and for my own knowledge.
I would have thought, that there was a definative way (casting numbers, stamps, etc.) to tell what these axles are. Engine blocks and many other parts have a way of being positively ID'ed........
Take care,
Misled
Old 02-27-2006, 01:24 AM   #5
1969 GMC
1969 GMC's Avatar
There may be, but it is not at all as well documented as Chevy engines.
EDIT: both of my Eaton 3rd members had the pinion and ring gear tooth counts stamped into them, and it looks like it was done by hand. I couldn't see any markings on the one that came factory with the locker.
It is an open diff, I can see spider gears in the 2nd pic.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-27-2006, 10:13 AM   #6
No differentiation because there`s no differencr,same parts.The difference is in the brakes/outer area.And,the fact that no HO52s were narrow.
Old 02-27-2006, 11:47 AM   #7
Rod
I did look up the casting number but it wasn't in my parts book. "3934635"..if the last number was a 4 then it would have been in there...but even so all it listed was the rear cover casting piece for 68-72 3/4 and 1 ton trucks.
Old 02-27-2006, 05:58 PM   #8
Longhorn Man
And no HO72's were set up for coils.
