Old 02-26-2006, 04:19 PM   #1
oatzy
Question Carb and distributor?
Hey guys, I want to get rid of the quadrajet on my truck and go with a holley carb. Which model is good? I am going to put the 290 hp gm crate engine in it, the truck is manual transmission. Also I would like to upgrade to HEI which conversion kit is the one to go with. I have heard a lot on the One Wire Distributor? Where can I get one decently priced. Oo Sorry it is a 71 3/4 ton 350 4 speed 4x4. Never really worked on carbs before just fuel injected datsuns so any pushing in the right distributor choice and place to get the stuff would help. By the way sorry for saying zcars on a chevy sight
oatzy is offline   Reply With Quote
Old 02-26-2006, 07:14 PM   #2
truckdude239
truckdude239's Avatar
Re: Carb and distributor?
i've heard alot of bad things about holly carbs but i am planing ona 650 cfm eldelbrock preformer carb
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-26-2006, 07:20 PM   #3
dennislbrooks
dennislbrooks's Avatar
Unless you are running HEI now, you may want to look at an Accel 71100E if you want vacuum advance -- yes you can spend more money and buy better. I run an Edelbrock also because I am not a Holley tuner.
dennislbrooks is offline   Reply With Quote
Old 02-26-2006, 08:38 PM   #4
pharcydekm
I have a 350 crate with the performer #2101 intake and edelbrock1406 carb. Runs great and you would not believe the performance difference. on the HEI I bought the cheapy $100 from AutoZone and it actually got the job done.
pharcydekm is offline   Reply With Quote
Old 02-26-2006, 11:38 PM   #5
jimfulco
Any particular reason you want to ditch the Q-jet?
jimfulco is offline   Reply With Quote
Old 02-26-2006, 11:44 PM   #6
krue
Designated A-hole!
krue's Avatar
Junkyard HEI should be fine for that engine. New cap, rotor and wires and you should be good to go. You can get better performance, but it costs a LOT more.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-27-2006, 02:13 PM   #7
68Stepbed
68Stepbed's Avatar
I would go with a stock HEI dizzy with a good cap, coil, rotor. I would run a 570 Holley Strret Avenger if you want a Holley. A 600 Edelbrock should be OK too. You will like the Street Avenger much better though.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-04-2006, 07:27 AM   #8
willow72
willow72's Avatar
Crate Demon Carb!
willow72 is offline   Reply With Quote
