Old 02-26-2006, 07:25 PM   #1
jkade
jkade's Avatar
Van tilt column in 72 Blazer, WIll it Fit?
Has anyone done this? What do you have to change? The end Shaft is 3/4" Splined and overall Length is 39" Main Body Diameter is 2" The Upper Housing Diameter is 4"
jkade is offline   Reply With Quote
Old 02-26-2006, 07:28 PM   #2
Huck
Huck's Avatar
Re: Van tilt column in 72 Blazer, WIll it Fit?
I have a van tilt in my blazer---no problem. Just modify like a truck and it bolts right in with the wire harness jumper.
Huck is offline   Reply With Quote
Old 02-26-2006, 07:31 PM   #3
jkade
jkade's Avatar
What do you have to modify?
Old 02-26-2006, 07:40 PM   #4
teamradrz1
teamradrz1's Avatar
I believe you just have to drill out the pin in the shaft so it can slide to the right length.
1971 Chevy Blazer CST 4X4
2012 Camaro 2SS/RS
2007 Avalanche 4X4
teamradrz1 is offline   Reply With Quote
Old 02-26-2006, 07:50 PM   #5
jkade
jkade's Avatar
Sounds simple.
Old 02-26-2006, 08:16 PM   #6
krue
Designated A-hole!
krue's Avatar
Check the FAQ submissions board. There's a thread on modifying a van tilt to work (mostly moving the Neutral Safety switch). If you can't find it look in my Index thread.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-26-2006, 10:23 PM   #7
jkade
jkade's Avatar
I found the info there. If the van column is longer can I move the column futher out of the dash? My seats go way back and it would be more comfortable to have it futher towards me. Will that help in any of the modifacition issues?
Old 02-26-2006, 10:49 PM   #8
jkade
jkade's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Did I pay too much?
