Life, Be In It.....
![]() Join Date: Oct 2003
How can I tell if I have the correct core support for my 68
I recall reading somewhere that there was a difference between the 67-68 core supports and the 69-72 core supports. Pic would be great.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
![]() Join Date: Aug 2001
Re: How can I tell if I have the correct core support for my 68
THE EAZIEST WAY THAT I KNOW OF IS TO LOOK ALONG THE BOTTOM FOR THE WELD NUTS FOR THE GRAVEL SHEILD. THEY WERE A 67-68 ONLY & THEY WON'T BE ON A 69-72 RAD. SUPPORT. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 02-26-2006 at 08:43 PM. |
![]() Join Date: Aug 2005
Can they be converted? I knew they were different, but what makes them incompatable?
If You Look On The Headlight Socket Welded To The Support There Is A Year Date On It. You Might Have To Clean The Crud Off First.
Vortec in the works
I just went through this on mine, 69-up core supports had headlight buckets spot welded to the support.
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
The biggest difference is the in the headlight mounting area. The 67/68 headlight buckets mount direct to the core while 69-72 core supports have brackets spotwelded to the core for the buckets. I should add this if for Chevys.
I think you can convert a 67/68 to a 69/72 core by adding the headlight bucket brackets but there are some differences in going backward from a 69/72 to 67/68. The stamping was changed to not roll the edge of the headlight hole out of the way like the 67/68. The nuts that John talks about are another difference. The lower valance was used only in 67/68. Chevy and GMC both used the valance. In 69 it was eliminated in both Chev and GMC. I think you could get by without it for all but a serious retoration 67/68. Another very minor difference is that early 67 core supports do not have the captured nut for mounting the dual note horn behind the left headlight. I am not sure when GM added this option and thus the captured nut. These are the biggest differences I have found but there may others I am not aware of. Hope this helps. Any other questions or comments please post them.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
I don't have a picture of the 67-68 but here is a sample of what mine on my 69 looks like. Hope this helps.
69 Chev K10, 350 4 bolt main, 202 "double humper" heads, healthy cam. edlebrock 600 cfm and preformer intake 3.73 ratio with posi rear. ![]() Check her out http://www.angelfire.com/ak6/1969k10/my_baby |
Life, Be In It.....
There is a ebay item that says it is a 67-68. Is this what I should be looking for?
http://cgi.ebay.com/ebaymotors/1967-...QQcmdZViewItem
Vortec in the works
That one is for 67-68 Chevy,not GMC
MY EX DRIVES A BROOM
only thing i can tell you is that if you want to use a 4core radiator the support in the ebay pic will have to be modified slightly
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
You Can NOT modify a 69-72 to fit a 67-68. The headlights are in diffirent locations side to side.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
