Old 02-27-2006, 11:07 AM   #1
kaycee
kaycee's Avatar
Exclamation A/C Fan Shroud
I need a shroud for my 69 A/C truck I was told that I needed to use a shroud from a 4wd.My motor is in the back motor mount posistion,it had about a 4"+ gap from fan to rad. Do I need one from a regular 2wd or do I need to get the 4wd one the 4wd are a little deeper correct? THANKS FOR THE REPLYS
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 02-27-2006, 04:01 PM   #2
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
Re: A/C Fan Shroud
The 4X4 is definately deeper. I have both at home I could measure for you, or possibly take some pics. Would be later tonight as I am at work right now.
Jason
jay_shy is offline   Reply With Quote
Old 02-27-2006, 05:26 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: A/C Fan Shroud
My understanding is that the rear position is only 2" back. It doesn't sound like a 4wd will be long enough if you have a 4" gap, but that is just a guess.
Why is your motor in the rear (4wd) position?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-27-2006, 06:37 PM   #4
kaycee
kaycee's Avatar
Re: A/C Fan Shroud
That is a estimate on the distance,my motor was put there cause I didn't want to lengthen my drive shaft.I'm running a sb with a 350 TH the truck was a 6 cyl 3 speed originally
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 02-27-2006, 08:55 PM   #5
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
Re: A/C Fan Shroud
Finally got home to take the pics.
The one on the right is for 4X4 and is about 9 inches deep.
The one on the left is for V8 and in 5 3/4 deep.
Jason
Old 02-27-2006, 09:11 PM   #6
71swb4x4
71swb4x4's Avatar
Re: A/C Fan Shroud
I have pictures from a couple years ago too, I will post them too jusst for the heck of it.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-28-2006, 12:23 AM   #7
kaycee
kaycee's Avatar
Re: A/C Fan Shroud
Yep I think a 4x4 one would do the trick for me,Would one from a 74 be the same ??Are any of you guys wanting to get rid of one???THANKS FOR THE REPLY AND PICS
2005 FXDWG stage3
63 IMPALA 327/4L60
