Old 02-27-2006, 12:33 PM   #1
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Turn signal lever/switch problems
I have an '86 Silverado with the cruise/turn signal/ washers/wipers/dimmer all on the same stalk. Last year it got difficult (almost impossible) to push my turn signal lever down to signal a left turn. The lever eventually broke off. I assumed it was a problem with the switch, so I replaced it (new AC Delco part) and the lever, stalk, or whatever you want to call it (aftermarket from the HELP! section). That made it work better for a few days (left and right requiring equal amounts of force to engage), and then it was difficult to push down to signal left again.
I pulled my column apart yesterday to tighten the tilt mechanism and try to fix the problem with using the left turn signal. I found that the left turn signal was difficult to push down because the black wire for the cruise control had worked its way between the stalk and the plastic housing for the column. Does anyone have pics of how that wire is supposed to be routed? I put it back together last night, moving it to another spot so that it did not interfere with anything, and it had already started working its way back by the time I got to work this morning.
Also, do others with this same stalk have minor difficulty getting the turn signals to come on? Even with the black cruise control wire pushed out of the way, it does not easily turn the left or right signal on. When I push on the lever, I have to push harder than seems natural to get it to click into place. It feels like there is a lot of flex in the whole assembly, like it is a cheap plastic part. No other vehicle that I have ever driven was like this, GM or not, so I suspect something is wrong. I can't find anything wrong, and the switch and lever are both new. I don't have access to anything else with this setup, so I don't know if it is normal.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
