Old 02-27-2006, 05:50 PM   #1
jostrans68
Jostrans68
jostrans68's Avatar
door mounting help!!!!!!!!!!
the plate on the cab bottom hinge fell in any ease way to fix
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 02-27-2006, 05:55 PM   #2
jhow66
jhow66's Avatar
Re: door mounting help!!!!!!!!!!
Fell in where?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-27-2006, 06:06 PM   #3
jostrans68
Jostrans68
jostrans68's Avatar
where the bootom hinge mounts to cab is hollow
[CGTW Member
Old 02-27-2006, 06:24 PM   #4
raggedjim
raggedjim's Avatar
Probably the easiest is to cut through the kick panel on the inside of the truck, that's an inaccessable area, but a common problem.
Once you cut out the kickpanel you should be able to figure out what you need to do.
Good luck Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 02-27-2006, 09:45 PM   #5
OhioChevy
Before you cut anything try using a piece of wire to fish it back up to where
you can get to it. It could not have fallen very far , not that much space
to drop.
OhioChevy is offline   Reply With Quote
Old 02-27-2006, 11:51 PM   #6
avejoe
Custer had a plan too.
avejoe's Avatar
BFM and slide it up
(Big F***ing Magnet)
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 02-28-2006, 01:15 AM   #7
jostrans68
Jostrans68
jostrans68's Avatar
tried magnet wire and all there is actually alot of space I cut a 1 in hole and reached around in there and gave it now has nuts and flat washers oh well it aligned of Thanks
[CGTW Member
