no brain no headache
Front crossmember...
Like an idiot,
![]() thanks in advance
1996 GMC Sierra z71 ![]() 1970 SWB 2wd (project) ![]() |
Re: Front crossmember...
Uh, you removed the '70 2wd truck's bolt-in engine crossmember/suspension cradle or the front crossmember which I thought was riveted in there? Another truck?
I'm easily confused. ![]()
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 02-28-2006 at 03:39 AM. |
engine/ suspention cradle
Bump
not sure of the size, but locktite would be a great idea and common practice on bolts/nuts that arent removed often
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end |
nobody
resU deretsigeR
YEEAAAAAAAHHH! I can help! I just replaced mine with 1/2" x 1" washer and lockwasher. I have about 3 threads hanging out the bottom of the nut. I took the old bolts to the hardware store and matched them up one by one per each size for my whole frame. There is plenty of room so if you want to go to 1 1/4" if your washers are thicker, no problem.
thannnnnk you sir
