02-27-2006, 11:47 PM | #1 |
lowering 67'... HELP PLEASE
im going to be doing some light hauling and moving the gas tank to the rear, so i am wanting to go with a 3" coil in the front, and 4" coil in the rear.. how low can these trucks go w/o needing to relocate the shocks and needing a new crossmember, also anyone have feedback on the "heavy duty" rear coils from classic performance products, thats where i've priced everything through.. give me some feedback fella's
02-28-2006, 08:22 PM | #2 |
Re: lowering 67'... HELP PLEASE
anyone w/some answers???
02-28-2006, 08:55 PM | #3 |
Cant answer your ? on the tank, but I have a 6 inch rear spring drop and haul a 400ex 4 wheeler and had it loaded down with some scrap a few weeks ago, and yes it did bottom out once when I went over a RR tracks too fast, but its not like it rides on the frame. Relocating your shocks is a preference just helps it ride a little better. 4 inch should be no problem at all. what are u planning on hauling and what tank do you plan on using?
1971 LWB Chevy C-10 350/350 3:42 eaton |
02-28-2006, 11:37 PM | #4 |
probably fuelcellguys tank, i roadrace, so i would haul a gsxr600 and possilbly haul a 5x8 enclosed trailer, i realize i might have to put some bags back there as well.. i just didnt know about the shock relocate kit
03-01-2006, 02:13 PM | #5 |
67 is sold
Checkout www.earlyclassic.com
they recommend rear shock relocators for pretty much any rear coil drop. Also, you'll need an adjustable panhard bar you should not need a rear crossmember with a rear spring drop. |
