Old 02-28-2006, 12:18 AM   #1
GlennBrittain
A long and expensive tail light saga
I put my 69 SWB work truck in the shop to fix a license plate light, tail lamp and turn signal problem. I decided to find and repair an exhaust leak first. My son had removed my stock exhaust and installed cheap headers with Flowmasters. To loud to find a leak by listening. I found a cracked header collector. One set of Hedman Elite’s about $325.00 later (misplaced receipts) exhaust leak is fixed. Now the headers are interfering with my auto shift linkage, motor is in I6 position. I decided to just install a floor shift, that I have been wanting, $187.00 later I am the proud new owner of a B&M light truck magashifter. On to the turn signal. Took my auto shift column tube and other parts from a floor shift column, and picked up and ordered parts totaling $322.00, installed a rebuilt and painted floor shift column, that resolved part of my turn signal problem. I am now $834.00 into this ordeal and still do not have a right turn signal, taillight or license plate light. I used a trailer plate light that I found in the shop, to solve the license plate light problem. I started at the column connector with volt/ohm meter for the passenger side tail and turn signal working my way back to the light assembly. I found the socket was full of sand and gunk, after a cleaning with WD40 better contact was made with the bulb. So $834.00 later I have lights, but I have not been to the muffler shop yet, still open headers.
GlennBrittain is offline   Reply With Quote
Old 02-28-2006, 12:58 AM   #2
cdowns
cdowns's Avatar
Re: A long and expensive tail light saga
sounds like my projects// at least all the body panels are still bolted on--------AREN'T THEY???
Old 02-28-2006, 01:00 AM   #3
Ron 586
RIP Mr Ron
Ron 586's Avatar
All this time I thought it was just me being punished for past transgressions. Now if you get a ticket for loud pipes on the way to the muffler shop I'll know where my long lost brother is hiding. Good luck with your project.
Ron (Mr Round Tuit)
Be kinder than necessary, for everyone you meet is fighting some kind of battle
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Ron 586 is offline   Reply With Quote
Old 02-28-2006, 01:11 AM   #4
GlennBrittain
All of the pannels are on this one, but I have two more 69's. I have had one stripped down to the frame now for 9 months. I still claim to be working on it but it just keeps getting pushed to the bottom of the list.
Old 02-28-2006, 02:15 AM   #5
Russell
Professional Grade
Russell's Avatar
Sounds a bit like my 80... Went into the shop cause the engine wasn't running properly -- It went in a rusty, carbed 2wd 3/4 ton truck with an auto trans, and is soon to come out as a rust free 3/4 ton 4x4 truck, with a standard transmission, and a fuel injected engine. Which, of course, doesn't run properly yet!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
