Old 02-28-2006, 11:15 AM   #1
shelby987
shelby987's Avatar
bleeding after wheel cylinder replacement
as many of you may have read, I lost a tire yesterday and screwed up my front axle. I need to replace the backing plate, all the pad hardware, and it looks like I puled a seal off the wheel cylinder. Do I need to replace cylinder, or is this just a dust boot that can be snapped back on?
Also, if I have to replace it, can I get away with only bleeding this one wheel, or do I need to bleed all four corners?
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 02-28-2006, 11:40 AM   #2
truckdude239
truckdude239's Avatar
Re: bleeding after wheel cylinder replacement
you can put the boot back on but io'd go ahead and replace it will its all apart you can bleed only one but i'd bleed them all for safey
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-28-2006, 12:29 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Take your finger and push the piston back into the cylinder and pop the boot right back on. You can open the bleeder screw and gravity bleed it for a minute or two to assure no air is in that wheel cylinder if you want to.
