English Chevy Owner
Dash pad
How easy is changing the dash pad on a truck? As part of my interior refurb I am considering a new dash pad as mine is somewhat worn and I'm wondering how easy/hard to change they are with the windshield in place? A previous owner covered the top of the dash in black vinyl which is now lifting so I may rip it all off and replace it with some to match my reupholstered door panels as I've got a load of red vynil left over. What would I have to remove to change it over?
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
SKINNY TIRES RULE!
Re: Dash pad
The dash pad only covers the edge of the dash facing you when your looking at it. It doesn't go all the way to the windshield. There is no reason to remove the windshield, but you will need to remove the instument cluster and glove box. If you have AC, you may need to pull the center vent. There are screws that are visable when you look directly at the dash pad and there is a series of nuts attached to bolts built into the dash pad. These nuts are the reason you need to remove the cluster and glove box.
If you have a cover that goes all the way to the windshield, it is probably something installed by a previous owner.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Re: Dash pad
keep the dash steel/paint.....Re vinal your dash pad...
$0.02
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
67-72 Addict!
Re: Dash pad
They make a dash cap that I have used several times and really like. It takes 10 minutes at most to install with the supplied adhesive and it looks great. LMC sells them for about $50.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#5 | |
Re: Dash pad
67-72 Addict!
Re: Dash pad
It attaches to the original with the supplied silicone. The old one supports it. Here is a before and after shot.
English Chevy Owner
Re: Dash pad
Thanks guys. The vinyl was put on the top of the dash by a previous owner, it's lifting around the edges. What I do with it depends on what it's like underneath. I really don't want to have to remove the glass to repaint it so if the paint is bad underneath it's gonna get upholstered again. No AC and the stereo head unit is coming out at the same time as I have a sub and amps to go in under the seat and I need to sort the wiring out for them. I also intend to add some concealed lighting in the footwells under the dash somewhere attached to some door switches as there is no illumination other than the dome light and thats not currently attached to any door switches. I want a nice fade in/out action for them.
SKINNY TIRES RULE!
Re: Dash pad
From what I've heard, the caps are hard and stick on with double stick tape. They "snap" on over the top of the old dash pad.
LMC sells courtesy lights and a fade kit.
Re: Dash pad
Thanks for that pic! It looks good.
English Chevy Owner
Re: Dash pad
I can source courtesy lights and a fade kit over here in the UK, no point in shelling out for shipping them across the atlantic and then paying another lot of tax on them! Thanks for the help guys, I think a new pad will make a big difference to the look of the cab as mine is somewhat battle scarred.
