Old 02-28-2006, 03:34 PM   #1
dougs69c10
dougs69c10's Avatar
hinge mount on door caved in
New guy here, 69 chevy c10 stepside, well i was lookin at the drivers door and the lower hinge area just rusted through and fell in. Is it something that can be cut from a donor truck and welded in or is there a patch piece or what not i can use
dougs69c10 is offline   Reply With Quote
Old 02-28-2006, 04:40 PM   #2
71SWBChevy
Post Whore
71SWBChevy's Avatar
Re: hinge mount on door caved in
I don't think they sell a patch panel for that but you could cut one out of a donor truck and replace it, just make sure you do a good job of welding it, it would kindof suck to get your project finished open the door and it just fall off
Drew
'71 Chevy 350/TH350 Hugger Orange
Currently just a rolling frame, body work soon to follow!!!
Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927
Daily Driver: 1997 Chevrolet S-10 with more gears than pistons
71SWBChevy is offline   Reply With Quote
Old 02-28-2006, 10:18 PM   #3
dougs69c10
dougs69c10's Avatar
yeah, last thing i want is the door fallin off.
off topic, i also have a grand prix 98 gtp actually
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end
Old 02-28-2006, 10:41 PM   #4
71SWBChevy
Post Whore
71SWBChevy's Avatar
Dude I think I just welcomed you in the welcome forum!
Drew
Old 03-01-2006, 12:37 AM   #5
Bob B.
I am afraid it's time for a new door.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 03-01-2006, 12:43 AM   #6
dougs69c10
dougs69c10's Avatar
the door is fine, its where the hinge mounts to the truck that caved in
Old 03-01-2006, 12:48 AM   #7
dougs69c10
dougs69c10's Avatar
Old 03-02-2006, 12:38 AM   #8
Bob B.
Yikes! There is a patch panel for the lower section of the pillar, but I don't think there is one that goes up to the hinge mount. You probably could use the lower section, and fabricate the rest. How is the reat of the cab? Might be easier to find a solid cab and replace the whole thing.
Old 03-02-2006, 02:52 AM   #9
dougs69c10
dougs69c10's Avatar
this is really the only bad spot on the cab. The floor in the current truck has 2 small holes by the seat belt, and the drivers side rocker panels are shot. Otherwise its fairly solid I found a donor cab im gonna cut this piece out of. 75 bucks for the cab. Its got a good front and rear window, figure i can prob get most of my 75 back just from sellin those two pieces.
Old 03-02-2006, 07:59 PM   #10
Bob B.
Not surprised the driver's side rocker is gone, too. The problem is water leaks in the hinge pillar through the fender and door hinge bolts. There's no drain in there, and it will start to eat the lower section of the pillar, and then the rocker. Your best bet would be to section in the pillar from another cab, and maybe use a replacement rocker.
