Blank
I'm interested in convert my steel bed to wood what's involved?
Anyone ever done this? My truck's bed has had a hard life and the floor is bent with some small rot. Buying a LWB and having it shipped to CT is near impossible. I think a wood floor would be a nice look and easy to get the pieces new and shipped. All and any info would be great.
![]() 1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi. 1977 Corvette 350-375hp 4speed, silver show car. 2002 S10 xtreme, work truck 2004.5 VW jetta GLI 1.8T 6speed, weekend warrior. 2013 Audi A3 TDI, the wife's car |
Post Whore
Re: I'm interested in convert my steel bed to wood what's involved?
You will need a new header panel for a wood bed instead of metal, you will need the bed cross supports for a wood bed instead of a steel and I think that is it, if you get an LMC catalog then it lists everything needed in there but I would buy the parts from a board dealer you'll get better prices and better service.
Almost forgot you will need the strips that go between the boards and boards!
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons ![]() Last edited by 71SWBChevy; 02-28-2006 at 04:44 PM. |
67-72 Addict!
Plus alot of money!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
![]() ![]() Join Date: Jan 2005
Blank
thanks this helped alot.
Out of the carpool lane.
Here are the differences in the header panels. The wood version is the deeper/taller one. I won't be using it if you need it. I also have some support beams that I think are for a wood bed, but I only have 2 + the rear one. Not sure how many are required.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
Here are pics you requested Speedracer. Sent you a PM
You will also need the rear crossmember for the wood floor. It has a step for the wood to fit into.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
