Old 02-28-2006, 09:52 PM   #1
boogie67
boogie67's Avatar
Pvc Valve
Can I hook up my Pvc valve from the valvecover to the vac on the intake.The one where the trans vac hooks up to will this work?
77 swb starting all over again.
boogie67 is offline   Reply With Quote
Old 02-28-2006, 10:28 PM   #2
cdowns
cdowns's Avatar
Re: Pvc Valve
i think it'd be better to use a pcv valve i think pvc will not work well
Old 02-28-2006, 11:58 PM   #3
jhow66
jhow66's Avatar
Re: Pvc Valve
Off carb-more vacuum pull. Also it will kill fuel signal to # 8 cylinder.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-01-2006, 12:40 AM   #4
boogie67
boogie67's Avatar
Re: Pvc Valve
The reason Im asking is I have no where to put my powerbrake at.If I use the one on the carb for the PVC valve can I put a Tee on the one on the intake and use it for the trans and powerbrake?Its a manuel choke carb. Thank you
Old 03-01-2006, 01:07 AM   #5
jhow66
jhow66's Avatar
Re: Pvc Valve
Will work fine that way as the trans and booster are both closed systems.
Old 03-01-2006, 01:31 AM   #6
BurnoutNova
BurnoutNova's Avatar
Re: Pvc Valve
can you elaborate why it would kill fuel signal? i know if you didnt have it hooked to port vacuum it would loose vacuum off idle, but i dont really understand the fuel signal thng.
BurnoutNova is offline   Reply With Quote
Old 03-01-2006, 10:21 AM   #7
jhow66
jhow66's Avatar
Re: Pvc Valve
I will try. If you install your PCV line on the intake at that point (intake runner to #8 cylinder) you will loose most of your vacuum pull to the PCV valve itself because it is "open" to the outside air. When # 8 cylinder is on the intake stroke it cannot pull any fuel in because the port is open to the outside air the same as if the intake gasket was leaking at that port. The reason you can put your powerbrake booster and trans modulator on the intake is that they are closed to the outside air. A PCV valve is just a controled vacuum. ( The above explanation comes from a 70 year "young" gear head-me) LOL
