Old 03-01-2006, 05:46 AM   #1
teamradrz1
teamradrz1's Avatar
need help IDing rear end
Need someone to look at this pic and hopefully tell me what I got I believe it is a dana 60 this is 8 lug 3/4 ton axle on 71 Chevy Blazer. Is it a locker, posi, or ???
1971 Chevy Blazer CST 4X4
2012 Camaro 2SS/RS
2007 Avalanche 4X4
teamradrz1 is offline   Reply With Quote
Old 03-01-2006, 08:26 AM   #2
CUSTOM/10
CUSTOM/10's Avatar
Re: need help IDing rear end
It looks like a dana, open diff. ( Not posi ) If it's a rear end 8 lug it's probably a dana 60. If it's a front end it could be either a 60 or a 44. There will be numbers on the opposite side of the diff. case shown in the pic. ( 44F or 60 )
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 03-01-2006, 12:30 PM   #3
teamradrz1
teamradrz1's Avatar
I'm sure it's a dana 60 amd it is the rear, I jacked up the truck had all 4s in the air and when I spun the tires they turn in the same direction on front and rear, my thought was if they do that you have posi or locker but I have no clue about axles of Diffs.
2012 Camaro 2SS/RS
2007 Avalanche 4X4
Old 03-01-2006, 01:47 PM   #4
CUSTOM/10
CUSTOM/10's Avatar
Both tires spinning in the same direction would be a possible indication of a posi, but the pic dosen't indicate that. Are there any clutch disks inside the ring gear ??? or just another side gear ???
Gary
72 SWB 4x4
My 72 SWB Build
Old 03-01-2006, 03:27 PM   #5
teamradrz1
teamradrz1's Avatar
I don't remember the Diff is all back together now it must be posi cause if I do a burnout, short one with 35"s, it does spin both tiresand it will kick the truck sideways.
2012 Camaro 2SS/RS
2007 Avalanche 4X4
Old 03-01-2006, 09:09 PM   #6
1969 GMC
1969 GMC's Avatar
yours is a dana track-lock clutch posi
this is an open diff:
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 03-02-2006, 12:29 PM   #7
teamradrz1
teamradrz1's Avatar
Thanks I knew someone out there would know. Thanks for the post!
2012 Camaro 2SS/RS
2007 Avalanche 4X4
