Old 07-22-2002, 04:20 PM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Remove Spindle - Help?
Do I need that special "ball joint removal" tool to remove the spindle from the upper and lower "A" arms? I thought they just popped off with a little tap from a BFH once the nuts were off!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 07-22-2002, 05:40 PM   #2
ThreeQuarter
ThreeQuarter's Avatar
It really helps to have a pickle fork. Sometimes it takes some heavy pounding even with them. They don't cost too much, less than $10. Good luck!
Ben
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 07-22-2002, 10:57 PM   #3
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Wink
But be carefult they tear the boots up then you gotta replace the ball joints. But if you got it apart you should do it anyway they are not that expensive, and worth doing now. I always use the BFH, and beat the hell outa it. hehe
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 07-23-2002, 09:38 PM   #4
CoryM
Ya usually they come off easy, but sometimes they absolutely will not come off without a pickle fork. 90% of the time i just sticka pry bar in there (or leave a light load on the springs) then hit the spindle.
CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada
http://www.geocities.com/chevroletc1070
"Take up our quarrel with the foe:
To you from failing hands we throw
The torch; be yours to hold it high."
Lieutenant Colonel John McCrae, Canadian Army
CoryM is offline   Reply With Quote
