Old 03-01-2006, 01:11 PM   #1
John Fabris
TOTY 2006
John Fabris's Avatar
700r4 with throttle rod question...
Hi All,
I am running a 350 v8 with a 700r4 transmission in the 67, in which I still have the stock gas pedal setup with the threaded throttle rod. What options do I have in finding the correct bracket to work with stock rod and still work the kickdown cable?
I tried looking at lokar, but it all looks like they need new throttle cables as well.
thanks..
John
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 03-01-2006, 01:43 PM   #2
Mixup
Re: 700r4 with throttle rod question...
Bowtie overdrives sell a plate that goes under the carb. I have one on my 69 and it works great.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 03-01-2006, 05:46 PM   #3
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
I have the same setup in my 68. I used a universal chrome throttle bracket kit that all parts stores pretty much carry. I did have to cut off the bracket for the accelerator to clear the rod but mine works great.
Ugly or not it still kicks a**!
stueber68 is offline   Reply With Quote
Old 03-01-2006, 06:27 PM   #4
72MARIO
72MARIO's Avatar
Go wiht the Bowite Overdrives kit. I have it under my Demon Great kit. It will work with your stock throttle rod. it's th T.V made EZ kit.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-02-2006, 05:54 AM   #5
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
i have the same set up in my 68' i went down to the local pick-a-part and pulled the bracket off of an 84 caprice, it's short enough to fit underneath your throttle rod. sorry no pics, as i am no longer in the country
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 03-02-2006, 08:10 AM   #6
Radman
Go with bowtie overdrives set up. it comes ith the new T.V valve set up and if you tell them what carb you are running they sendyou a part that attaches to our carb and it makes the tv valve adjustable from soft earlier shifts to hard If you do not get the tv valve adjusted right it will tear your trans out. go to their web site as it explans everything for you. That cable adjusts your trans pressure and also tells it when and how hard to shift.
Radman is offline   Reply With Quote
Old 03-02-2006, 04:09 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'm with sixty8c10, I always use donor brackets from vehicles I've parted out.
Old 03-02-2006, 04:57 PM   #8
72MARIO
72MARIO's Avatar
Yha but the Bottie Overdrives kit is killer.
And you need a kit to correct the gemoetery with aftermarket carbs. Junk yard stuff is good if you go with all one setup.
2005 TAHOE DD
