03-01-2006, 09:58 PM | #1 |
are these original????
wondering if these are correct.. they were in a 71 blazer where the wing window screws are. the door didn't have the usual dimple it had a hole there with these in them. are they correct? and are they reproduced? Thanks, Devin.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
03-01-2006, 10:04 PM | #2 |
Re: are these original????
i believe only the 72 doors had the dimple,but i have never seen those,maybe its just a blazer thing
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
03-01-2006, 10:04 PM | #3 |
Yep.
03-01-2006, 10:05 PM | #4 |
Yes they are correct. AFAIK, they are not reproduced so don't loose them!
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
03-02-2006, 06:45 PM | #5 |
Yes they are correct for 69-71 Blazer/Jimmy. In 72 all doors had the dimples.
70 Jimmy 4x4 71 GMC 2500 Too bad stupidity isn't painful |
