Old 03-02-2006, 04:13 PM   #1
67 cst swb
67 cst swb's Avatar
Firewall Insulation...?
I'm soon starting the reassembly of a 68 SWB 2WD...
So. What did you use for replacement firewall insulation? O.E.Factory replacement or something else? Where is the best place to get the O.E.Replacement stuff, Which seller's on the board here sell it?
Thanks for any info...
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 03-04-2006, 07:39 PM   #2
wibilly
wibilly's Avatar
Re: Firewall Insulation...?
i'm thinking of trying somthing different, don't know how it will work. i 'm going to try ice and water shield used for roofing on my floors under carpet for a sound deadener in addition to the carpet pad i think i'll use it in my doors a back of cab and on firewall in addition to factory stuff or a cheaper version of somthing like dynamatt it has an adheive back and with a heat gun will conform to conturs very well. anyone else tried this?
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-04-2006, 07:46 PM   #3
72armyswbtruck
72armyswbtruck's Avatar
That sounds pretty close to what was original in some of the late model gm's It's like tar/rubber that is molded and adrears to the floor, Sounds like a good idea using the roofing stuff
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-04-2006, 07:55 PM   #4
BubbaGreen
I have purchased the oem version from two different vendors...
and I think KennysTrucks sells the best available for the firewall.
Chevyduty sells rubber retainer plugs that are identical to the original.
As for sound deadening, dynamat, or a similair product is going to be way more effective than tar/roofing paper, because it adheres to the surface, it will remove the vibration/resonance, along with heat that would normally transmit thru sheet metal. But anything is better than nothing.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 03-04-2006, 08:08 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
GQ has the factory replacement stuff installed in it, the PO did it b4 I bought it
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-04-2006, 08:19 PM   #6
wibilly
wibilly's Avatar
bubba i'm not talking about tar paper ice and water barior is about 1/8" thick adhesive backed rubber
Old 03-05-2006, 08:55 AM   #7
NitroMike
Active Member
NitroMike's Avatar
Wibilly,
Think you may be on to something. Might try it on my '67. Think I'll paint the floor first with Eastwood's rust inhibitor, then Ice Shield, jute and carpet.
The older I get, the faster I was!!
NitroMike is offline   Reply With Quote
Old 03-05-2006, 09:58 AM   #8
cdowns
cdowns's Avatar
www.coollizard.com only if you want sstate-of-the-art technology
Old 03-05-2006, 11:29 AM   #9
Rokcrln
Rokcrln's Avatar
I just sent off for their info as a few customers have asked for this as well. For my own vehical I will probaly go with this on the under side of my cab and then on the floor and inside firewall.
I think the ice shield should work fine for your application. The only thing I would be concerned about would be smell when it gets hot. It would really suck to find this out after the truck is back together.
Kevin
Rokcrln is offline   Reply With Quote
Old 03-06-2006, 02:59 PM   #10
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
I've heard that the roofing product, as well as brown bread, and some other vibration reduction products have a "tar" smell for the first couple of summers. I've considered this for my truck when I get the rust taken care of. It won't matter that much since it is a work truck. It is not something I would want in a show vehicle.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
