03-02-2006, 08:52 PM | #1 |
18 Circuit Painless Wiring Question
Does Anyone Know If The 18 Circuit Painless Wiring Harness That Costs 309.00 Comes With The Plug That Plugs Into The Ignition Switch. The Picture On The Website Only Shows A Generic Photo Of A Harness. The Plastic Behind My Ignition Switch Id Melted So I Need Another One. Someone Told Me That This Harness Might Be A Wire In. But I Hope Someone Has One And Can Tell Me Does It Just Plug Into The Ignition Switch Or What.
Please Help Thanks Gary Day |
03-02-2006, 08:54 PM | #2 |
Re: 18 Circuit Painless Wiring Question
probably not, a new plug is less than 20 bucks, switch is about 20, and the rest is cheap, but if you buy all the necessary parts, expect to spend over 50 bucks. more like 75 if you're not getting the good deals.
03-02-2006, 09:05 PM | #3 |
where do i get the plug. i have been looking everywhere. my local parts store told me that they don't have it. do you have a link or part number?
03-02-2006, 09:34 PM | #4 |
Active Member
yes it comes with one, got mine from Summit, 18 circuit for our trucks
Has all connectors, IIRC the only ones you have to attach are the headlight ones. Has provisions for 2 or 4 headlight setups Jason ________ Cbr400 Last edited by Jayss109; 04-27-2011 at 11:34 PM. |
03-02-2006, 09:38 PM | #5 |
Thank You Very Much .. I Love This Site
03-02-2006, 09:52 PM | #6 | |
brothers.
http://brothersonlinestore.com/prodi...number=SWI72PL Quote:
03-02-2006, 11:48 PM | #7 |
someday it will be done!
all connections but the cresent shaped one on the steering column.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
03-03-2006, 01:58 AM | #8 |
Active Member
03-03-2006, 09:26 AM | #9 |
Really?Mine didn't.Hmmmmm wanna trade?
03-03-2006, 10:33 AM | #10 |
'69 Step
It does come with it; just finished mine.
03-03-2006, 05:28 PM | #11 |
mine didn't come with one either. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
03-04-2006, 04:25 PM | #12 |
ok.. here is a good question then. of those of you who had one come with it, where did you get yours. the others that didn't have one come with it. where did you get yours? I wanna get mine in the same place that you got it if it came with it.
03-04-2006, 05:10 PM | #13 |
Active Member
Got mine from summit. Painless Part # 10206 Summit # PRF10206
Mine came with both connectors for the steering column. The NON-halfmoon was installed on the wires, so follow the directions carefully to remove it and install the halfmoon one. Not hard, but can screw up the wire ends if your not careful. And keep track of which wire goes where. Their directions are very complete. Just take your time and lay everything out and plan it well. once everythings mocked in, start tie wrapping, wire looming whatever yyou preffer. Keep yourself to a 3 beer minimun as well! Have fun Jason ________ Honda civic (sixth generation) Last edited by Jayss109; 04-27-2011 at 11:34 PM. |
03-04-2006, 05:15 PM | #14 |
i'm buying from summit then today. thanks.
3.5 beers |
03-04-2006, 05:27 PM | #15 |
Life, Be In It.....
Those of you that have it and istalled it can you show pics of it on the firewall? What type of hole did you make for the wires to go through to the engine bay?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
03-04-2006, 05:30 PM | #16 |
Active Member
Comes with a template to enlarge the Stock hole in the firewall. Engine bay section fits in the hole and connection is made there with a bolt to the fuse panel. Hardest part is getting a tool in there to make the hole bigger. I'll try to get some pics later today... Gotta go down and try on my new wheels and check for backspacing! Woohoo... damn only have 1 beer...and its not cold.. DOH
J ________ Ship sale Last edited by Jayss109; 04-27-2011 at 11:35 PM. |
03-04-2006, 05:54 PM | #17 | |
Life, Be In It.....
Thanks, pics would be great. As for the beer, well with the weather we have been having, in the bay area lately, leave it outside for 5 minute and it will probably be frozen.....
03-04-2006, 05:55 PM | #18 |
PROJECT 7DEUCE
My summit kit painless kit came with the half moon..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-04-2006, 08:41 PM | #19 |
Active Member
Heres a couple I snapped. Man, sure looks dirtier when its closeup like that ...
Oh crap, files too big, heres a link instead Jason http://web.mac.com/jason_hall/iWeb/S...20harness.html ________ AVANDIA LAWSUITS Last edited by Jayss109; 04-27-2011 at 11:35 PM. |
03-05-2006, 01:27 AM | #20 |
So the painless kit comes with all the plugs you need to install it? I didn't know that. I've been trying to decide what harness to buy (my original is toast), and this sounds like a good idea. The only problem is I'm not running the stock gauges, radio, HEI, electric choke, washer pump, van tilt, etc. Would a guy like me be better off with a generic hotrod harness or the painless unit? (Sorry for the thread hijack).
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
03-05-2006, 01:40 AM | #21 |
Active Member
Mudd... I wasnt running ANY gauges when I started. This Kit has provisions for electric gauges and idiot lights too. Now I have all autometer gauges, msd ignition. Only thing I had to add was the Big power wire to the MSD box, everythign else is there. I think half the stuff with the kit, i didnt use...elec fans, power windows, EXTRA long fuel level sender wire (for under bed tanks), Heater or AC stuff, and who knows what else. You can go for the smaller setup, non 18 circuit one if you dont need all the bells and whistles. I just went for it because I know I'll need/want it in the future. Just insualted them and tied them up for later use.
I think its a good buy and good product... saved alot of headaches when mine melted down under the dash. Like I said before, just take your time, and double check everything. Jason ________ Charger (1999 Concept) Last edited by Jayss109; 04-27-2011 at 11:35 PM. |
03-05-2006, 03:14 AM | #22 |
Life, Be In It.....
Jason.....
How many of the original wire hole on the fire wall did you end up using? I an going to have my fire wall smooth and close up the used holes.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 03-05-2006 at 03:16 AM. |
03-05-2006, 12:23 PM | #23 |
Active Member
IIRC Im using the "oil pressure hole" above for my vaccum line and something else for the wiring. In my picture you can see Im using the speedo hole as well, but thats add on stuff, not from the painless kit, so could be routed a better way(got lazy on that one). I would keep the "oil pressure hole" and the "wiring hole" above it. Or one of them atleast. Would suck to smooth it all out, then find out you need a hole for something! Find some plugs for future use. IMHO
Jason ________ Vapir vaporizer Last edited by Jayss109; 04-27-2011 at 11:35 PM. |
03-05-2006, 12:34 PM | #24 |
That looks like a way nicer harness than the one I was going to use:
http://www.itsasnapwireandcable.com/new_page_6.htm It's more than twice the price, but it looks like it comes with all the connectors I'd need, plus its specifically designed for the job, and not just some generic streetrod harness like the "It's a Snap" one.
03-05-2006, 03:01 PM | #25 | |
thats why ill probley go with painless. |
