Old 03-03-2006, 07:50 AM   #1
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Big Block Z-Bar ....
Does anyone have the complete z-bar assembly for a big block '71 ? I have been looking for a long time with no luck.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 03-03-2006, 11:03 AM   #2
ScottH
ScottH's Avatar
Re: Big Block Z-Bar ....
Not to highjack the thread, but is there a difference between SBC & BBC z-bars?
ScottH is offline   Reply With Quote
Old 03-03-2006, 02:12 PM   #3
72armyswbtruck
72armyswbtruck's Avatar
What is one and what does it look like? I might have one if you can show me a picture or explain to me where it is at.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 03-03-2006, 02:19 PM   #4
sakohntr
sakohntr's Avatar
There is no difference.....
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 03-03-2006, 08:05 PM   #5
Bishops Trucks
KEEP ON TRUCKIN'
Billsbowtie has one for a small block but said it will not fit a big block. Thats the reason I started this thread. If there is no differance I will take what anybody has. Just let me know... 72army, look in parts for sale, billsbowtie has a picture of one. If you have one I will take it.
JIM
Old 03-03-2006, 09:34 PM   #6
fast_dev
fast_dev's Avatar
im told they are not different, but if you don't change the bracket on the frame it won't work. i just did a big block swap with a stick. i used a 6 cyl z-bar (had to cut a little off the end, has no effect on function) with the 6 cyl push rod from the pedal (had to file the back a little to clear the header, can't even see it on the truck) and you can modify the pivot ball bracket by moving the ball. i'll see if i can get pics for you. a correct big block pivot ball is pretty hard to find. Devin
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
Old 03-03-2006, 10:04 PM   #7
Bishops Trucks
KEEP ON TRUCKIN'
Thanks fast dev, I would welcome pictures if you can get some. When you say change the bracket on the frame, do you mean move it back or swap with a differant year ? Appreciate your input.
Thanks, Jim
JIM
Old 03-03-2006, 10:34 PM   #8
ScottH
ScottH's Avatar
I'm going to do this as well later this year, would also appreciate pics or other helpful insights.
Thanks.
Old 03-03-2006, 11:37 PM   #9
fast_dev
fast_dev's Avatar
sorry for the crappy pics, i'll get better ones, i'll also take some pics of the factory big block stick truck i have but that will have to be over the weekend. for now heres what i got. pic 1 is of the modified pushrod. pic 2 is the modified pivot ball. this is from a small block truck, grind the weld off the back of the ball then you will have to grind on the bracket to get it to fit on the big block, then bolt it to the motor and put the z-bar in. mark your bracket and drill a new hole for the ball and weld it in from the backside. this is using the correct big block towers also. Dev.
Old 03-04-2006, 07:48 AM   #10
Bishops Trucks
KEEP ON TRUCKIN'
Thanks Dev,
Pictures are worth a thousand words.
JIM
