Old 03-03-2006, 08:53 AM   #1
greg0380
anyone ever grab their shaft.....
of the steering column. THe piece that connects the steering box and goes towards the firewall. Is there a way to take out the play, mine seems to have a lot of slop. Unless this is normal..
1985 GMC Sierra 1500, 1/2 ton, 2WD, LWB, TBI 305
5 speed, 3.42 rear
2007 GMC Sierra 1500, xtended cab, 4X4, flexfuel 5.3L
1999 BMW 528i
greg0380 is offline   Reply With Quote
Old 03-03-2006, 11:59 AM   #2
Army_Dude
Re: anyone ever grab their shaft.....
Yes, there are acouple of articles linked in threads here. Look a couple pages back. I haven't done it myself (but need to!). It's 4 bolts but getting to them seems to be the trick.
Army_Dude is offline   Reply With Quote
Old 03-03-2006, 06:44 PM   #3
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
There are the 4 bolts that Army Dude talked about. These are bolted to the ragjoint. I've tried to find a replacement at stores but no luck. The universal setup in the HELP! section didn't even work. If you can get a dealership to work with you on fidning the part you might be able to find on there and replace it.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-03-2006, 07:39 PM   #4
1976K5CHALET
1976K5CHALET's Avatar
Still ava from the dealership. I replaced mine in the 79 years back. The 73 to 77-8 crowd will have problems as they switched to a double d connector at the bottom of the steering column from the splined version used in the older trucks. Not sure but either I-DID-IT or somewho doesn't come to mind right away makes replacements that have ujoints at both ends and do away with the rag joint. While its apart you might want to check the lower column bearing just behind the metal cover held in place with a spring clip...their famous for being short a ball or two.
DW
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
