'69 Step
My truck fights me.
Seems my truck fights me tooth and nail on things I do. I just finished my "bolt in" LMC hitch receiver behind a flip down license plate and roll pan on a 3/5 drop truck. To get the hitch where I wanted it, I had to cut the ends off, flip the whole thing, drill it, weld new brackets on it, and finally weld it in. My "Painless wiring harness" wasn't SO painless trying to match the Vintage Air, Dakota Digital, and MSD ignition box into it. In the end, it is worth it and fun; but man, do any parts go together easily??
Jamie Hyneman is my twin
![]() Join Date: Nov 2005
Re: My truck fights me.
Simple answer is NO
Would you want it any other way.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
it';s called fabrication// you should've been around in the old days ==== we'd just start with imagination and go from there!!!! everybody's just lookin for ""off the shelf "custom""
Whats a bolt on ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
No,I DON'T have Tourett's
If it was easy, everbody'd be doing it.
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
![]() Join Date: Sep 2000
If it went in easy than some thing is missing or wrong
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
Whenever something doesn't need to be modified to work or all the parts are included, I think s*** must have done something wrong...
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
Designated A-hole!
There's a reason it's called "working" on your truck.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#9 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Yep been there done that if you want something that you built it will fight you all the way...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
