03-03-2006, 02:06 PM | #1 |
need help with top install specs
help ! i am tring to fix the old girl. i am getting ready to do the floor boards and tring to get the top aligned first. how far back from the door jam should the top be. any help greatly appreaciated thanks in advance oh its a 72 blazer
03-03-2006, 02:34 PM | #2 |
Re: need help with top install specs
i'm at work so I cant measure but when i was working on mine I bolted the windshield part doent and jacked up on the body a litlle till my front holes lined up once I got them in I just bolted in the rest and it held.
back to the question. mines a double wall and it comes right up to the edge maybe 1/4 back so there is room for the stripping. you could measure on the bootom of your top from the front bolt forward and then do it on the bedrail. 69k5 |
03-03-2006, 03:38 PM | #3 |
I put new rubber in mine and still cant get the windows to seal. theres a 1/4" gap between my drivers window and the rubber in the top. I'm just having fits getting mine to line up. I hope you have better luck than I.
03-03-2006, 04:22 PM | #4 |
The LuvShack Garage
Hmmmm, there are no adjustments available on my top that I know of
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
03-03-2006, 05:18 PM | #5 |
SKINNY TIRES RULE!
The problem is probably in your body mounts. If they are shot, you may have experienced some sagging once you took the top off. I know the top on my '72 doesn't fit around the door windows as nice as it did before I took it off for the first time. I probably should have replaced the body mounts before I pulled the top.
You might be able to jack up the center of the body and get the doors to align. I believe I read about this someplace on the board.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
03-03-2006, 07:19 PM | #6 |
Thanks for the input all. the door was lining up with the with the door jamb and rocker panel ok it was at the top of the wind sheild post that was tight. I thought the top needed to move forward more to push the windsheild out. after about 4 or 5 times of measuring things i found the door is tweeked. time to weld in some braces and get busy with the floor.
