Old 07-22-2002, 07:11 PM   #1
dion
72 Cheyenne
dion's Avatar
Stall Converters
Do you guys like them? I'm probably going to put a 2500 in.
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 07-22-2002, 07:28 PM   #2
68 with 350 TPI
68 with 350 TPI's Avatar
well yes they can make your truck/car go faster
I have this to say about most converters.
"JUNK".
I know a lot of people that run a cheap converter and they get by but for the most part a off the shelf converter is junk.
The only ones worth anything are the ones with furnace brazed fins,heavy duty bearings,anti ballooning plates etc.
I would advise to get a good converter you need to give a lot of info about your engine,trans,rear gearing,weight of the vehicle etc.
But then again if you just want a faster take off on the street and you dont have a really built engine Im sure a B&M/TCI will do fine.
But I have not had good luck with either company for draging with full slicks.
I would say talk to art carr,huges,fairbanks and get a custom built converter for a little more than a off the shelf (1 size fits all cars within a stall range) converter.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 07-22-2002, 09:32 PM   #3
dion
72 Cheyenne
dion's Avatar
Thanks for the info. I'm getting a B&M 2500
Burnout
Idle
1972Cheyenne
1966/67Stouts
