Old 03-03-2006, 05:39 PM   #1
makovai
makovai's Avatar
anybody have a bone stock 4x4 blazer
Could you please do me a favor pleeeeeeeeeeeease?
1.)I want to know the distance from the ground to the center of the hub
2.)from the ground to the top of the front fender wel
3.)from the ground to the rear fender.
When I bought this rig i was told it has a 6" suspension and a 3" body.
I think it has a 4" suspension and a 3" body. I really want to know.
Thank you
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
Old 03-03-2006, 05:49 PM   #2
70rs/ss
70rs/ss's Avatar
Re: anybody have a bone stock 4x4 blazer
Bone stock that is 33 years old is not going to get you accurate info. I have seen a post or two that says 6" but I/they think its 4" because it has a 4" block (total close to 6" lift). Well 4" is pushing it for a block height, so they usually do 2" spring and 4" block. As for being accurate, lift kits are said to be +/- 6" as trucks weigh different, settle etc (I6 vs SBC vs BBC). What is the "reason" you "need" to know if it is 4" or 6"? If the tires fit etc without rub why are the numbers important? I am just curious, I have a "Bone Stock" Blazer, except the tire size, so my measurements might not help.
70rs/ss is offline   Reply With Quote
Old 03-03-2006, 05:59 PM   #3
71RestoRod
71RestoRod's Avatar
You can measure from the top of your front axle to the bumpstop mount. Stock height measures about 8", a 4" lift about 12" and a 6" lift about 14".
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 03-03-2006, 06:29 PM   #4
makovai
makovai's Avatar
good answer that will work....thanks alot.
I have no good reason for wanting to know this except, I want to know
www.fast77.com
1996 Z71 w/ 35's
Old 03-03-2006, 07:57 PM   #5
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Sorry, mine is bone stock except for the wheels and tires and lift. I can measure them for you if you want. It has 33x12.5's and factory slots. I think the lift is a 4 inch blocks in the back. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 03-03-2006, 11:14 PM   #6
makovai
makovai's Avatar
Actually that would be a good referance as well. measure from the top of the axle housing (not the differential) to the bottom of the cross member just under the oil pan by the motor mounts. use the lowest point of the cross member.
I was told my rig has 9" but i think it's only 7".
www.fast77.com
1996 Z71 w/ 35's
Old 03-04-2006, 10:33 AM   #7
Are you an engineer?j/k
Old 03-04-2006, 03:57 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
If you have blocks in the back how tall are they ? The blocks are usally 2'' shorter than the lift
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-04-2006, 04:30 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Cool Info
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-04-2006, 06:02 PM   #10
Medicanman71
Medicanman71's Avatar
Just measured, came out to 13.5"
Medicanman71 is offline   Reply With Quote
Old 03-04-2006, 06:18 PM   #11
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Yeppers, me too, the PO was right about my lift 11.5"
Old 03-04-2006, 09:01 PM   #12
red71cheyenne
Back in the sticks
It measured 7.5 inches from the axle to the crossmember. The blocks in the back measured only about 3". So do I have a 3 inch lift?
2011 K1500 Suburban
2014 K1500 Pickup
Old 03-04-2006, 09:25 PM   #13
Medicanman71
Why dont you measure the way suggested?
"You can measure from the top of your front axle to the bumpstop mount"
Old 03-04-2006, 10:57 PM   #14
red71cheyenne
Back in the sticks
Might do that. Personally, I'm not really concerned, it is what it is.
2011 K1500 Suburban
2014 K1500 Pickup
