03-03-2006, 07:52 PM | #1 |
Just here to help
Fluid question
hey guys,i got the tc in and bolted up with a new (well different) driveshaft,now i would like to go ahead and fill everything up while i have it on stands.What i need to know is what goes where?The tc is bolted to a turbo350 so dextron 111?front end(dana44)80-90?rear end same?thanx guys for all of your help!!!What a COOL BOARD!!
03-03-2006, 09:22 PM | #2 |
Re: Fluid question
Any GL-5 gear oil for the diffs and NP205 transfer case. 80-90w is a good compromise between 75-90w and straight 90w. The TH350 auto trans fluid should stay separate from the adapter and xfer case if the seals do their job.
If either diff has a clutch-pack limited slip, then limited slip additive is warranted.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
03-03-2006, 10:39 PM | #3 |
Just here to help
Re: Fluid question
I do know the rear has a posi in it,so what would you recomend?
03-04-2006, 12:12 AM | #4 |
Re: Fluid question
If you get 80-90 or 75-90 with the GL-5 rating it will be posi friendly.
03-04-2006, 02:34 PM | #5 | |
Compatible with synthetic and petroleum gear oils and most limited slip differentials. If limited slip chatter occurs, add AMSOIL Slip-Lock friction modifier additive. Boss, friction modifier is available at dealers, most auto parts stores, 4x4 acc stores, and speed shops. On line too, of course, but shipping on a couple oz would be ridiculous.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 03-04-2006 at 02:36 PM. |
03-04-2006, 03:01 PM | #6 |
Just here to help
Re: Fluid question
got them filled up with 80-90 GL5 and also put in the posi additive in the rear.Now i just need to let it down and hope everything works...lol.Wish me luck
03-05-2006, 01:57 AM | #7 |
Designated A-hole!
Re: Fluid question
Good luck.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
