Edelbrock Carburetor
I want to change my carburetor to an Edelbrock carburetor. Is a 1400 with electric choke a good move and should I just keep the stock manifold or change to a Edelbrock 2101. My blazer is just a dailey driver With a bone stock motor.
One more question. Where is a good place to buy this carb.? Thanks guys
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html |
The LuvShack Garage
Re: Edelbrock Carburetor
Me personally, if it's the OE equipment your gonna replace I would just
remove the carb and intake as a unit, box it up, and keep it on a shelf, as for where to buy, www.jegs.com and or www.summitracing.com ![]() just remember not to go overboard (To big of intake or to much cfm's)
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 03-04-2006 at 08:44 AM. |
I've tried several variations---the edelbrock 1406 with electric choke is about as good a choice as you can get. Rather then going to a different intake, I recommend you stay with the original --just use an adapter for the different size venturi holes (orig small and big oO---Edelbrock= oooo). Going to a "performance intake" only resulted in a drop in gas mileage for me. Intakes really need to be matched to cam shafts to get the desired results. That also goes for exhaust headers. Staying close to stock has worked better for me in every case. The exceptions are---go to an HEI distributor eliminating the points and condenser---much better reliability. Also go to the internally regulated altinator eliminating the voltage regulator with mechanical points. Better charging. My .02
Thanks Huck,
You just saved me about 115.00. I allready put in the HEI distributor.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
You cannot go wrong with the carb upgrade I run a edelbrock on my daily driven blazer and it has worked great in the 3 years its been on there..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
![]() Join Date: Apr 2000
i agree with huck, i got a 1406 on my blazer(along with the other mods he mentioned) but i got an aluminum intake,i dought it would matter to you in texas,but my blazer is cold natured and it helps it warm up a little faster,unlike huck i`m not retired and i got to drive to work in some pretty cold mornings
![]() just make sure you get the eletric choke, i got a 1405 and its a manual, i hate it....
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com Last edited by jamie72; 03-04-2006 at 05:04 PM. |
![]() Join Date: Feb 2004
I agree, go with that electric choke, I had a manual choke and hated it. JM2C
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Whats the differance in a 1400 and a 1406?
What Part number adapter plate do I need? Thanks
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html Last edited by HatGuy; 03-05-2006 at 01:27 AM. |
